performance help
Old Jan 7, 2007 | 07:56 PM
onefastx's Avatar
Default performance help
for starters i just did a jdm b16 swap into my 93 delsol and im bored i want more power im thinking cams supercharger ecu flash anyone who could give me some feedback as to what works well together or ideas i would appreciate it
Old Jan 7, 2007 | 07:57 PM
I Shot 50 Cent's Avatar
Check the stickes at the top of the forum, there's alot of helpful information in there.
What power goals are you looking to achieve? Engine parts work together as a package.
Old Jan 7, 2007 | 09:41 PM
gezzuzz's Avatar
Default Re: performance help (onefastx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by onefastx &raquo;</TD></TR><TR><TD CLASS="quote">for starters i just did a jdm b16 swap into my 93 delsol and im bored i want more power im thinking cams supercharger ecu flash anyone who could give me some feedback as to what works well together or ideas i would appreciate it</TD></TR></TABLE>
turbo!!!!!!!!!
Old Jan 7, 2007 | 09:43 PM
WhiteOnRice's Avatar
How much more power? And how much cash do you have?
Old Jan 8, 2007 | 01:21 PM
onefastx's Avatar
Default Re: (fizix_skate)
i dont know about turbo i need this to be reliable i want to put down around 250hp i have heard that turbo b16's = blown motor as far as money no more than 4000
Old Jan 8, 2007 | 01:24 PM
Relic1's Avatar
for $4k, go with a turbo kit and have it dyno & street tuned. Power and reliability. (provided your tuner is good)
Old Jan 8, 2007 | 01:39 PM
adonis2oo2's Avatar
people have this myth that turbos blow everything upp??? i dont get it
Old Jan 8, 2007 | 01:51 PM
onefastx's Avatar
Default Re: (adonis2oo2)
i have just heard that b16s +turbo=bad. If i do a turbo set up i will not go with a kit i know i can build a lot more power buying seperate products and if i do go turbo i already have a stainless turbo manifold so help with turbo i have a tubular turbo manifold, what size turbo what kind what else do i need ideas on where and what to get
Old Jan 8, 2007 | 03:02 PM
doood's Avatar
been there done that
take a look in the forced induction forum. lots of guys with stock b16's making some very good numbers.
Old Jan 8, 2007 | 03:09 PM
Syndacate's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adonis2oo2 &raquo;</TD></TR><TR><TD CLASS="quote">people have this myth that turbos blow everything upp??? i dont get it</TD></TR></TABLE>
It's simply b/c there's so many idiots that slap a FI build together untuned and wonder why they have pistons sticking out of the block a week later.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by onefastx &raquo;</TD></TR><TR><TD CLASS="quote">i dont know about turbo i need this to be reliable i want to put down around 250hp i have heard that turbo b16's = blown motor as far as money no more than 4000</TD></TR></TABLE>
If you're going for 250whp then you might as well use forged internals and stay safe. 250whp is high for a B16 stock internals. Usually 180-220 is a good safe zone (maybe 230, 240 if dyno tuned) on a good tune. If you're going as high as 250 you might as well get forged internals and run 350 with bigger injectors and pump (simply by cranking up the boost after a tune).
A supercharger almost acts as natural aspiration. It gives a very solid tq. curve unlike a turbocharger which has to spool up. Though I wouldn't recommend it for a B16. It's a 1.6L engine so it doesn't have that much tq. to begin with. Superchargers are good on bigger engines where the rotational mass of the supercharger's belt doesn't put too much stress on it, on a B16 it's like having the AC on, then adding your 8lbs of boost or so. Turbos are spun by exhaust fumes - they don't add any stress to the motor's function.
Basically what I'm saying is 10lbs on a turbo will get you further than 10lbs on a supercharger assuming they're the exact same size. The tq. curve won't be as strong on the turbo until it spools up, but the end result will be noticeably higher.
So with that said, it comes back to the very obvious questions:
- What are your goals? (power wise, 250 at the wheels?)
- What's the car's usage? (daily driver, weekend driver, show car, etc.)
- How much do you have budgeted for upgrades (speaks for itself)
Old Jan 8, 2007 | 03:14 PM
onefastx's Avatar
Default Re: (Syndacate)
its a dd and this is just the kind of info im looking for in basics i need more so if 200whp is more reasonable i will shoot for that like i said 4000 is it for now and that is max and i have the manifold already so what else would i need to make these numbers safely
Old Jan 8, 2007 | 03:29 PM
doood's Avatar
Default Re: (onefastx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate &raquo;</TD></TR><TR><TD CLASS="quote">If you're going for 250whp then you might as well use forged internals and stay safe. 250whp is high for a B16 stock internals. Usually 180-220 is a good safe zone (maybe 230, 240 if dyno tuned) on a good tune. If you're going as high as 250 you might as well get forged internals and run 350 with bigger injectors and pump (simply by cranking up the boost after a tune).
300-350whp is completely safe on a b16 with the right combination of parts and good tuning
Old Jan 8, 2007 | 03:30 PM
Syndacate's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by onefastx &raquo;</TD></TR><TR><TD CLASS="quote">its a dd and this is just the kind of info im looking for in basics i need more so if 200whp is more reasonable i will shoot for that like i said 4000 is it for now and that is max and i have the manifold already so what else would i need to make these numbers safely</TD></TR></TABLE>
With that budget? Ha. You can build a FI wonder .
Go with a mid-size turbo such as a DSM eclipse/talon turbo or saab turbo. The T3/4 would also work good here but is a bit bigger, that's fine though. Piece together a turbo kit.
Or buy one direct from Greddy. You can buy one brand new (entire setup) for your motor for 3,245. Not what I would do but always open as a suggestion.
I would piece together your kit, just get all the components used, shop around, you should be able to piece one together for around 1500 - 2k bucks.
You can run 200whp safely on a dyno tune. Run a P28 chipped ECU with a tuning program (I suggest crome). You'll have plenty left over for the tune. You can have it tuned relatively conservatively (like a 12.3AF) so there's a very very low chance of slinging a rod. You could probably run 220 or so if you have it dyno tuned. You could even ask the dyno tuner what he would recommend, they usually see quite a few turbo honda builds.
So you do that, you could probably come out, assuming 2000 for the turbo build, installation is easy and can be done by yourself. Maybe 450, 600 (as most shops charge 150/hr and it usually takes 3 or 4 hours to tune) for the tune. Then you can run that power daily w/o a high chance of ******* the engine up, you can pound on it, make good #'s, and that'll be that.
Old Jan 8, 2007 | 08:30 PM
adonis2oo2's Avatar
ivbe had much sucess with b16's they seem to be very strong motors... ive had one on 12lbs and one on a 150shot of spray both held up quite well
Old Jan 9, 2007 | 05:49 AM
onefastx's Avatar
thanks for the advice guys it is much appreciated
cslegacy
Dec 19, 2006 06:03 PM
JDM Pheen
11
Jun 24, 2006 02:00 PM
racerose
28
Jun 15, 2006 01:11 PM
Vtak DOHCTA
Feb 15, 2006 04:31 AM
integrated_bob
Oct 12, 2004 06:25 PM
