Rear wheel bearing - 93 accord EX, auto, ABS
Old Jan 7, 2007 | 06:23 PM
jojo69's Avatar
Default Rear wheel bearing - 93 accord EX, auto, ABS
Hi guys,
I just want to double check something about my rear wheel bearing.
- As I was reading the archieve, I concluded that the rear wheel hub is easy to remove. JUST PULL IT OUT after removing main nut.
Is it that easy?
Do I need any special tools?
Thank you all again
Joe
Old Jan 7, 2007 | 06:48 PM
Itz Darave's Avatar
if its drum its as easy as taking out the hub nut... took me 10 minz total, but i had air tools and a lift.. lol
Old Jan 8, 2007 | 01:39 AM
jojo69's Avatar
Default Re: (Itz Darave)
I have rotors & pads.
How EASY is it to remove it?
What kind of grease should I use also to grease it?
It is making winding noises
Thanks,
Joe
sde780
40
May 15, 2012 10:32 AM
Guteman
Jul 17, 2007 04:52 AM
Vt3c_eg
Mar 20, 2007 11:56 AM
zgrimes
Oct 18, 2001 07:32 AM
