crankshaft question
Old Jan 7, 2007 | 06:08 PM
ge_itr's Avatar
Default crankshaft question
is it possible to use any of the f23a's crankshaft on a h22a1 block? i see that it has 97 mm stroke which will give more torque correct? will anyone disagree with this swap?
Old Jan 7, 2007 | 06:11 PM
ge_itr's Avatar
or will the h23 with 95mm stroke be better?
Old Jan 7, 2007 | 06:13 PM
vinuneuro's Avatar
Default Re: (ge_itr)
f23 wont fit h22a1 block. the f23 has 55mm mains like the h22a4. h22a1 is 50mm.
Old Jan 7, 2007 | 07:10 PM
ge_itr's Avatar
the mains are the thickness of the crankshaft that's bolted between the block and the girdle correct? what do i have to do to change the mains? do i just have to and resurface that part on the block and the girdle?
Old Jan 7, 2007 | 07:20 PM
mgags7's Avatar
you can have the block machined to fit the bigger mains
more stroke should make more torque, just make sure you punch all the numbers correctly so you don't have pistons hitting heads and valves, etc....
AirbornManJuice
Jan 20, 2015 09:54 AM
OXY95LSSC
Northern California (Sales)
Dec 20, 2011 04:27 PM
bjones
Apr 19, 2008 09:13 AM
gosu08
Sep 9, 2006 07:51 AM
1G_DX_to_2G_Si
Oct 26, 2005 05:32 PM
