Handheld device for reading RPMs
Old Jan 7, 2007 | 06:00 PM
Nataku's Avatar
Default Handheld device for reading RPMs
My Haynes manual says when setting the idle, with the IACV unplugged, use a hand held tach to set the idle at 450 + or - 50 RPMs.
Now, the factory tach only goes down to 500 RPMs and I would doubt it's ability to be accurate that low.
What devices do you guys use when setting the idle?
Old Jan 7, 2007 | 06:38 PM
John Z's Avatar
Default Re: Handheld device for reading RPMs (Nataku)
if your running obd2 computer a hand held scanner should show within 50RPM.
Old Jan 7, 2007 | 07:20 PM
confidence's Avatar
Default Re: Handheld device for reading RPMs (Yaz)
a good automotive dvom will have an inductive pickup for this.
ie: Fluke 88
Old Jan 7, 2007 | 08:08 PM
Nataku's Avatar
Default Re: Handheld device for reading RPMs (confidance)
can I get some links to this stuff? thanks.
EDIT: are you talking about the scanners they loan from auto zone?
Civicman86
Jul 10, 2007 02:40 PM
HondaHeddie
Dec 11, 2006 02:06 PM
BYT
Jul 16, 2002 09:37 PM
SiKSiR
Mar 20, 2002 03:56 PM
