Hids on high beam only!
Old Jan 7, 2007 | 05:29 PM
JDM-EJ698's Avatar
Default Hids on high beam only!
well I recently put hids(PnP kit) in my car.but in oreder for them to work I have to have my high beams on for them work.Is there any way I can use them without putting my high beams on?Its on a 98 Hb.
Old Jan 7, 2007 | 05:34 PM
Archidictus's Avatar
Unceasing Measure
Default Re: Hids on high beam only! (JDM-EJ698)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM-EJ698 &raquo;</TD></TR><TR><TD CLASS="quote">well I recently put hids(PnP kit) in my car.but in oreder for them to work I have to have my high beams on for them work.Is there any way I can use them without putting my high beams on?Its on a 98 Hb.</TD></TR></TABLE>
You could try wiring them correctly...if the socket you used is making the highbeam indicator come on, switch it to the other one.
importnoodles's Avatar
have u thought that maybe you wired it wrong? Duh....
Eran's Avatar
HT White Ops
Default Re: Hids on high beam only! (Archidictus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus &raquo;</TD></TR><TR><TD CLASS="quote">
You could try wiring them correctly...if the socket you used is making the highbeam indicator come on, switch it to the other one.</TD></TR></TABLE>
QFT.
Old Jan 7, 2007 | 05:38 PM
JDM-EJ698's Avatar
Default Re: Hids on high beam only! (importnoodles)
There is only 1 way to plug it in.It came wired.All i had to do was install it.and everything was installed as told by the instructions.Its a pnp kit.
Old Jan 7, 2007 | 06:10 PM
JDM-EJ698's Avatar
Nobody knows???
Old Jan 7, 2007 | 06:32 PM
Hatchy-Ownzjo0's Avatar
H-T Poker champion
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM-EJ698 &raquo;</TD></TR><TR><TD CLASS="quote">Nobody knows???</TD></TR></TABLE>
Try again.
You failed at installing it.
Old Jan 7, 2007 | 06:40 PM
dude.. just switch the positive wires on the harness around. The positive wires on the PNP kit's harness. The 3 plug one that looks like the 3 plugs on your H4 lightbulb. Switch the positive wires. If theres only 2 wires then switch that positive wire to the other positive connector. Just find out which of the 3 is the negative and leave that one alone. Switch whatever other wire there is, to the other pin and you cant mess up.
Old Jan 7, 2007 | 06:41 PM
vollrathian's Avatar
Default Re: Hids on high beam only! (Hatchy-Ownzjo0)
maybe the kit u baught only has hid bulbs for high beam ive seen kits that are only for low/high beam or both
Old Jan 7, 2007 | 07:51 PM
H-T Poker champion
Default Re: Hids on high beam only! (vollrathian)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vollrathian &raquo;</TD></TR><TR><TD CLASS="quote">maybe the kit u baught only has hid bulbs for high beam ive seen kits that are only for low/high beam or both </TD></TR></TABLE>
No. That's not the problem. There is no HID kit strictly for high beams. He installed it incorrectly, or the instructions for installing are wrong.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by importnoodles &raquo;</TD></TR><TR><TD CLASS="quote">dude.. just switch the positive wires on the harness around. The positive wires on the PNP kit's harness. The 3 plug one that looks like the 3 plugs on your H4 lightbulb. Switch the positive wires. If theres only 2 wires then switch that positive wire to the other positive connector. Just find out which of the 3 is the negative and leave that one alone. Switch whatever other wire there is, to the other pin and you cant mess up.</TD></TR></TABLE>
Exactly. I didnt think it was that hard to figure out on your own, but there you go.
Old Jan 8, 2007 | 01:34 PM
JDM-EJ698's Avatar
the instrutions were incorrect.but I fixed it.thanx you guys.
Old Jan 8, 2007 | 02:29 PM
Malakai's Avatar
How did u tell if they are on high beam only. I have a set installed and mine may be like this?
I have a hi/lo kit, but i dont think it does ****.
Old Jan 8, 2007 | 11:49 PM
The Si's Avatar
You have the wiring switched around sopose to be HID on low beam
Old Jan 9, 2007 | 01:10 AM
TranspeedMotorsports's Avatar
You need to pull the metal peice off and stick it in another slot.
Old Jan 9, 2007 | 02:52 PM
JDM-EJ698's Avatar
Default Re: (Transpeed Motorsports)
^thats what I realized I had to do.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Malakai &raquo;</TD></TR><TR><TD CLASS="quote">How did u tell if they are on high beam only. I have a set installed and mine may be like this?
I have a hi/lo kit, but i dont think it does ****.</TD></TR></TABLE>
when i turned my normal lights on,nothing happened.turned on high beam and BAM they worked.
Old Jan 10, 2007 | 01:15 PM
Malakai's Avatar
ok, well mine are right then. but i have no high beams, cause they shine in the air. LOL
No way to adjust them.
mikeycivic
123
Mar 10, 2007 12:52 PM
XxIchiBaNxX
Mar 9, 2005 07:38 AM
XyKo
Feb 18, 2005 03:46 PM
LoW620
May 25, 2004 09:51 PM
slowpokeHB
Sep 12, 2003 12:40 AM
