Hids on high beam only!
well I recently put hids(PnP kit) in my car.but in oreder for them to work I have to have my high beams on for them work.Is there any way I can use them without putting my high beams on?Its on a 98 Hb.
Unceasing Measure
Re: Hids on high beam only! (JDM-EJ698)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM-EJ698 »</TD></TR><TR><TD CLASS="quote">well I recently put hids(PnP kit) in my car.but in oreder for them to work I have to have my high beams on for them work.Is there any way I can use them without putting my high beams on?Its on a 98 Hb.</TD></TR></TABLE>
You could try wiring them correctly...if the socket you used is making the highbeam indicator come on, switch it to the other one.
HT White Ops
Re: Hids on high beam only! (Archidictus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus »</TD></TR><TR><TD CLASS="quote">
You could try wiring them correctly...if the socket you used is making the highbeam indicator come on, switch it to the other one.</TD></TR></TABLE>
QFT.
QFT.
Re: Hids on high beam only! (importnoodles)
There is only 1 way to plug it in.It came wired.All i had to do was install it.and everything was installed as told by the instructions.Its a pnp kit.
H-T Poker champion
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM-EJ698 »</TD></TR><TR><TD CLASS="quote">Nobody knows???</TD></TR></TABLE>
Try again.
You failed at installing it.
Try again.
dude.. just switch the positive wires on the harness around. The positive wires on the PNP kit's harness. The 3 plug one that looks like the 3 plugs on your H4 lightbulb. Switch the positive wires. If theres only 2 wires then switch that positive wire to the other positive connector. Just find out which of the 3 is the negative and leave that one alone. Switch whatever other wire there is, to the other pin and you cant mess up.
Re: Hids on high beam only! (Hatchy-Ownzjo0)
maybe the kit u baught only has hid bulbs for high beam ive seen kits that are only for low/high beam or both
H-T Poker champion
Re: Hids on high beam only! (vollrathian)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vollrathian »</TD></TR><TR><TD CLASS="quote">maybe the kit u baught only has hid bulbs for high beam ive seen kits that are only for low/high beam or both </TD></TR></TABLE>
No. That's not the problem. There is no HID kit strictly for high beams. He installed it incorrectly, or the instructions for installing are wrong.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by importnoodles »</TD></TR><TR><TD CLASS="quote">dude.. just switch the positive wires on the harness around. The positive wires on the PNP kit's harness. The 3 plug one that looks like the 3 plugs on your H4 lightbulb. Switch the positive wires. If theres only 2 wires then switch that positive wire to the other positive connector. Just find out which of the 3 is the negative and leave that one alone. Switch whatever other wire there is, to the other pin and you cant mess up.</TD></TR></TABLE>
Exactly. I didnt think it was that hard to figure out on your own, but there you go.
Re: (Transpeed Motorsports)
^thats what I realized I had to do.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Malakai »</TD></TR><TR><TD CLASS="quote">How did u tell if they are on high beam only. I have a set installed and mine may be like this?
I have a hi/lo kit, but i dont think it does ****.</TD></TR></TABLE>
when i turned my normal lights on,nothing happened.turned on high beam and BAM they worked.
XyKo
02-18-2005 03:46 PM
