Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Speed: Si coupe vs. Si sedan
Old Jan 7, 2007 | 05:13 PM
L-Dawg's Avatar
Default Speed: Si coupe vs. Si sedan
So I've read numerous threads that've talked about speed comparisons of the Si sedan vs. the Si coupe. I remember hearing that the sedan is almost a second to slower to 60 -- but I've also read that it would be a "driver's race." If the coupe is in fact a second faster, this would hardly be a driver's race.
Are there any reliable sources that compare the two, or at least give a semi-accurate measure on the Si sedan's actual speed?
Thanks!
Old Jan 7, 2007 | 05:15 PM
Caveman74's Avatar
Default Re: Speed: Si coupe vs. Si sedan (L-Dawg)
Sedan would be a little heavier. So that might be the cause
Old Jan 7, 2007 | 05:22 PM
RICO_'s Avatar
NO MERCY!
Default Re: Speed: Si coupe vs. Si sedan (Caveman74)
I don't know about a full second....but the Sedan will be slower cause it's heavier.
Old Jan 7, 2007 | 05:42 PM
mkselecta's Avatar
Default Re: Speed: Si coupe vs. Si sedan (RICO_)
I'm thinking about an Si sedan, so I looked into this. The sedan is about 60 pounds heavier than the coupe. Everything else is pretty much the same. Sounds like a driver's race to me - skill and weight - I know drivers that are 60 pounds heavier than I am.
Old Jan 7, 2007 | 06:04 PM
will_rex's Avatar
Default Re: Speed: Si coupe vs. Si sedan (mkselecta)
I've never driven a coupe, but my 4 door Si seems to be fairly quick for stock. I've owned an ITR and 2 EVO's and honestly it seems to be eqaul to the ITR although it's been a while since I drove it stock and only subtly different from the EVO at highway speeds, obviously no comparison off the line. With only a 60 lb difference, it would seem to me to be a driver's race.
Old Jan 7, 2007 | 08:39 PM
blownEP3's Avatar
Default Re: Speed: Si coupe vs. Si sedan (will_rex)
Interesting.. That would be something else if 60 lbs could make that noticable of an impact on 0-60mph. Not a bad weight difference considering slightly more glass weight and all the impact beams, motors and regulators. Man I love Honda
Old Jan 7, 2007 | 08:47 PM
elohel's Avatar
Default Re: Speed: Si coupe vs. Si sedan (blownEP3)
A full second slower? Doubtful, very. Maybe like 2 tenths of a second slower. 60 pounds is nothing. Slim down to 100 and you're already competing with the coupes!
Old Jan 8, 2007 | 01:48 AM
bgangsta180's Avatar
Default Re: Speed: Si coupe vs. Si sedan (elohel)
yea has to be a drivers race because the driver in the sedan can weigh 160 and the driver of the coupe could weigh 220...now its even so truely its a drivers race
Old Jan 8, 2007 | 02:54 AM
RICO_'s Avatar
NO MERCY!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by will_rex &raquo;</TD></TR><TR><TD CLASS="quote">I've never driven a coupe, but my 4 door Si seems to be fairly quick for stock. I've owned an ITR and 2 EVO's and honestly it seems to be eqaul to the ITR although it's been a while since I drove it stock and only subtly different from the EVO at highway speeds, obviously no comparison off the line. With only a 60 lb difference, it would seem to me to be a driver's race. </TD></TR></TABLE>
2006 Si (I/H/E...probably tuned to) vs. stock '04 Evo 8 on highway.
http://videos.streetfire.net/v...b.htm
Enjoy!
Old Jan 8, 2007 | 06:30 AM
IT GUY's Avatar
The standard in 1/4 mile has kinda always been 100 lbs per tenth of a second. Not quite sure how that works out in zero to sixty, but I don't see 60 lbs making a seconds worth of difference. A big reason I could bring myself to buying a sedan was that it only weighed 60 lbs. more, thought I might be able to keep up with the coupes.
Old Jan 8, 2007 | 06:35 AM
Jay2005's Avatar
Default Re: Speed: Si coupe vs. Si sedan (IT GUY)
alright so what about the aerodynamics of the two cars, wheelbase difference, suspension differences...anyone know any differences here...sure the straight away would be close but how about an actual course with turns...
Old Jan 8, 2007 | 06:39 AM
cnyej1's Avatar
Default Re: Speed: Si coupe vs. Si sedan (Jay2005)
The second slower thing came from a magazine that had tested a coupe, and then a few months later tested a sedan. The coupe did a 0-60 of 6.7, while the sedan was a 7.4
Old Jan 8, 2007 | 02:47 PM
mkselecta's Avatar
Default Re: Speed: Si coupe vs. Si sedan (cnyej1)
This doesn't sound unreasonable. I see different magazines report different numbers on the same cars all the time. Launch techniques and conditions vary, and there are differences between individual cars too. I'll bet if they used the same driver under similar conditions (air temp, gasoline, tires, miles on engine, etc) and used several examples of each type of car, the times would start to come a lot closer. Do you know what magazine it was - I'd like to check out what they have to say about it.
Old Jan 8, 2007 | 03:14 PM
HondaF1Fanatic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mkselecta &raquo;</TD></TR><TR><TD CLASS="quote">This doesn't sound unreasonable. I see different magazines report different numbers on the same cars all the time. Launch techniques and conditions vary, and there are differences between individual cars too. I'll bet if they used the same driver under similar conditions (air temp, gasoline, tires, miles on engine, etc) and used several examples of each type of car, the times would start to come a lot closer. Do you know what magazine it was - I'd like to check out what they have to say about it.</TD></TR></TABLE>
Automobile.
Jon
Old Jan 8, 2007 | 04:32 PM
Tadehi's Avatar
Schumacher '10 WDC
Default Re: Speed: Si coupe vs. Si sedan (HondaF1Fanatic)
I just happened to be reading Motor-Trend and they said that the Sedan was about .2 yes 2 tenths of a second slower... That said anything under 75lbs. is a drivers race.
Old Jan 8, 2007 | 04:40 PM
cnyej1's Avatar
Default Re: Speed: Si coupe vs. Si sedan (Tadehi)
Magazines cant be trusted either..... like I siad I have a magazine stating that it does 0-60 in 7.4 seconds which is like .7 slower than the coupe.
Old Jan 8, 2007 | 05:51 PM
RICO_'s Avatar
NO MERCY!
Sounds about right
Old Jan 8, 2007 | 07:28 PM
94IntegraLs04's Avatar
they are both the same wow one wiehgt in wut 50 pounds more
Old Jan 8, 2007 | 07:31 PM
The only way you can trust a magazine is if they somehow correct their numbers to represent the exact same climate conditions at the exact same track with the exact same driver. Not possible.
Jon
Old Jan 9, 2007 | 04:46 AM
RICO_'s Avatar
NO MERCY!
Default Re: Speed: Si coupe vs. Si sedan (94IntegraLs04)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94IntegraLs04 &raquo;</TD></TR><TR><TD CLASS="quote">they are both the same wow one wiehgt in wut 50 pounds more </TD></TR></TABLE>
Actually it's more on the order of 60-70 lbs. more for the Sedan
Old Jan 10, 2007 | 08:08 PM
mkselecta's Avatar
From Automobilemag website:
"In our tests, the sedan, which is 59 pounds heavier than the coupe, took 7.4 seconds to reach 60 mph, versus 6.7 seconds for the coupe."
They don't have an explanation for the difference in times, but I doubt you can blame the 59 lbs.
I looked at Edmund's, and the 0-60 times for various tests of the '06 coupe range from like 6.8 to 7.5. Pretty volatile, so small differences don't mean much. I'd be interested to see what C&D gets out of the sedan - they correct their tests for weather conditions and seem to launch all of their test cars pretty aggressively.
Old Jan 10, 2007 | 08:10 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mkselecta &raquo;</TD></TR><TR><TD CLASS="quote">I'd be interested to see what C&D gets out of the sedan - they correct their tests for weather conditions and seem to launch all of their test cars pretty aggressively.</TD></TR></TABLE>
C&D seems to be the least variable because of their methodology but it still is a crap shoot unfortunately.
Jon
Alcatrax30
Apr 21, 2016 01:18 PM
BigC-ivic
63
Sep 2, 2009 08:15 PM
FG_Coupe
15
Sep 15, 2007 01:47 PM
TauMax
Jan 28, 2007 09:40 PM
cgjarvis
Mar 27, 2006 01:45 PM
