Need help with B-seires hood clearenss!
hey all, I just got done putting my GSR swap into my '89 crx si and am having problems with the valve cover conecting with the hood when I close it.
I have already put washers at the heng points and it still seems to be rubbing.
with out going JMD Sir front end, or CF hood is there a USDM hood that with clear a B-seires motor with out cutting it up
Thanks for your alls help
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsxr1k05 »</TD></TR><TR><TD CLASS="quote">i dont know if the b16 is not as tall as the b18, but i use hasport and no clearance problems at all.
B16 is shorter by something like 11mm (don't remember exact number).
The only way is to cut the webbing under the hood.
I am using Hasport mounts and it still rubs. Cutting the webbing is my only choise? The only reason I dont want to go CF is because I really dont like the look of hood pins.
thanks for the info.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Zaakro »</TD></TR><TR><TD CLASS="quote">yeah it should clear. but if you have Ebay mounts you will run into this problem.
Innovative mounts and Hasport can both clear a B20 and probably some others do too</TD></TR></TABLE>
A B20 block is just as tall as a B18 block. The PR3 and P72 heads sit higher than the non-vtec heads and thus would make a B18c taller than a B20. Either way, the Hasport mounts will be very close with a B20 (probably still touches) and the B18c WILL touch.
This is all using HASPORT mounts.
tweakit
Jul 12, 2004 05:47 PM
