b16 swap obd HELP
Old Jan 7, 2007 | 04:15 PM
egb16pg's Avatar
Default b16 swap obd HELP
i just got a b16a1 on my 95 civic ex. i have noo clue what obd wiring harness that i will i need to plug in to be obd1. the obd harness on it doesnt match my eg and believe is obd0. i already have a p28 since my civic is an ex and is obd1.
Old Jan 7, 2007 | 04:26 PM
gezzuzz's Avatar
Default Re: b16 swap obd HELP (egb16pg)
you can put the obd-1 harrnes from your civic on to the b16a motor..
do you have a hydro trasmission?
Old Jan 7, 2007 | 04:36 PM
egb16pg's Avatar
Default Re: b16 swap obd HELP (gezzuzz)
yea its hydro. i had a d16y6 or w.e its called before. the wiring harness doesnt fit. the fuel injector plugs wont get in.
-thanks
Old Jan 7, 2007 | 04:43 PM
gezzuzz's Avatar
use your civic injectors.. they the same size
Old Jan 7, 2007 | 04:50 PM
egb16pg's Avatar
so the harness should be fine other than that? thanks alot man
Old Jan 7, 2007 | 04:53 PM
gezzuzz's Avatar
you wil be missing the fan switch.. obd-1 motor its on the thermastat housing.. on obd-0 motors it on the back of the motor (bigger witha different plug)... you also need a obd-1 dizzy..
Old Jan 7, 2007 | 05:18 PM
egb16pg's Avatar
yea the distributor plugs dont match up. can i use the sohc distrubutor? lmao and the plug next to the oil filter doesnt reach.
Old Jan 7, 2007 | 05:38 PM
gezzuzz's Avatar
you may have to extend some of the wires to reach the sensors.
under the head in the back of the motor there is the knock sensor..
you will not have a plug for that one on your harness
you need a distrubutor for a obd-1 dohc vtec..
crx-
Aug 7, 2015 09:00 AM
SpeedOFsmell
Apr 17, 2013 06:55 PM
lejeaune
Apr 21, 2010 09:31 AM
haccord550
Jun 5, 2005 04:57 AM
1991hondahead
May 8, 2004 05:22 AM
