Nitrous Rings????
I dont think there as any such thing as a "nitrous ring". Your best bet would be oem or hastings rings for oem pistons. If you get aftermarket pistons then use the rings they supply.
Yea when i said nitrous rings i meant like something alittle more durable then stock. Ive searched and searched and havent found anything.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NJIN BUILDR »</TD></TR><TR><TD CLASS="quote">The oem rings are as strong as the stock pistons.</TD></TR></TABLE>
yep, you'll be at the mercy of the oem pistons more so than the rings. if you ever do a build with an aftermarket piston, just speak with whoever makes the piston.
