the best of the best suspension db8
hi all you ht guys i need some help i just purchased a 96 integra db8 and wanted to know the best coilover suspension that is available , this car is going to be a daily driver for me and cost does not matter i want to know what the best of the best is , the car will never see the drag strip but i am picky on my parts, ok guys i need all the top guys help here thanks in advance for all your help.
The most expensive, isn't always the best...But I'll tell you of the set ups that I've had in the past and liked..Tein SS with edfc, you can play with it untill you find your favorite setting..and also Koni yellow with a tein ss spring or eibach.
Motons but they will run you upwards of 5K and will need rebuilds every 8 months. It will probably be extremly uncomfortable as well.
Honestly you need to search.
How much of a drop are you looking for?
Some good setups that I can recommend are Koni Yellows with Ground Control Coilovers, or PIC. Im sure there are other setups that are good but I don't know much about them or hav any personal experiance with them.
Ali
Ali
ok i guess i was a little vague sorry guys i need an awsome street setup that is comforitble for every day use i will be lowering the car between an 1inch to an 1inch and 3/4 i'll be rolling on 17 inch rims just want somthing that'll last and offer great feel i dont want a bouncy ride more of solid yet comforitinle ride quality
Koni Yellows with whatever springs give you your desired ride height.
Do a search on Koni Yellow shocks and you will find all the info you could want.
Ali
Ali
you dont need a full coilover setup if you never intend to track the car (drag or circuit). it'd be a waste of money imo. just get some koni yellows and the springs of your choice. or ground control coilovers paired with the koni's if you want height adjustability.
xchosun1x
20
Apr 11, 2003 05:43 AM
