Will MF 10 16x7 +50 clear Spoon caliper?
I'm not positive but I think +50 will NOT clear, however the + 43 will allow your wheels to clear the Spoon calipers.
How much did you pay for the 4-pot Spoonies?
This is something that never made sense to me. Ben at A&J said that they WON'T fit under a 50mm offset 16x7" Mugen rim but WILL fit under a 50 mm offset 15x6" stock rim. Why is this??
50mm offset 15x6" stock rim
The answer is in Bold
Also Spoke shape comes into consideration also.
I believe the millenias have everything identical to stock.
(can you tell i'm a little pissed) I even took a dremal to the calipers
and still was not enough. Getting some 3mm spacer from Brian over at fastbrakes tomorrow to try them out. Thanks Brian, you kick ***.Craig - Who got 8 tires mounted on rims that don't work
I'll let u know if the 3mm spacer works. I took off the washers that you space the calipers off the knuckles and this moved the calipers in about 2mm, but i was short about .5mm I cut down the spoon goodness with the dremal where it was hitting, but .5mm is alot and I did not want to tempt it. We will see tomorrow after work
Craig - Who is dying to try his azenis
typerboy349
Jul 23, 2001 11:19 PM
