can get my crx started
Old Jan 7, 2007 | 10:33 AM
crxrider07's Avatar
Default can get my crx started
finaly got my electric workin good enough to get power when i turn the key but now after that nothin happens. i hear no noise or nothin what should i check? i am daelin with a 89 crx with almost completed dohc zc swap
Old Jan 7, 2007 | 10:47 AM
A.'s Avatar
A.
Huh? You mean it wont start. Check altenator, plugs and wires, Battery fluid, and if that doesnt work, check the ignition. Do the ignition as a last option thing since that will be the hardest to check. I am not sure what you are asking but I kind of took a guess.
Old Jan 7, 2007 | 11:47 AM
hott95ej2's Avatar
Default Re: (A.)
engine ground?
Old Jan 10, 2007 | 03:08 PM
AndrePerras's Avatar
Default Re: can get my crx started (crxrider07)
clutch pedal switch
Old Jan 10, 2007 | 03:37 PM
ExemptedNut's Avatar
Default Re: can get my crx started (AndrePerras)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AndrePerras &raquo;</TD></TR><TR><TD CLASS="quote">clutch pedal switch</TD></TR></TABLE>
x2, I have a bad pedal switch in a new car and damn thing wont do anything but light up if it doesnt engage right
Old Jan 10, 2007 | 06:40 PM
busted240's Avatar
Did you at any time switch the pos and neg hookups on the batt? if so it could be a fried ign switch. happened on my rx7.
Old Jan 13, 2007 | 10:46 PM
djcharlee's Avatar
Default Re: (busted240)
x3 on Clutch pedal switch, I just got under the dash and disconnected it.
cdust
Feb 15, 2018 05:34 PM
ki11r0y1086
Jun 20, 2016 06:45 PM
boost and bass
May 26, 2012 10:07 AM
CFDOHCVTECEG
Jun 6, 2007 10:10 AM
wood
Aug 16, 2005 07:09 PM
