AIR BAGS HELPPPPPP
Old Jan 7, 2007 | 10:01 AM
caraudiofaq's Avatar
Default AIR BAGS HELPPPPPP
HAS ANYONE REMOVED A PASSENGERSIDE AIR BAG BEFORE? IF SO I NEED HELP?
Old Jan 7, 2007 | 10:03 AM
T.J.'s Avatar
Default Re: AIR BAGS HELPPPPPP (caraudiofaq)
What exactly are you having problems with?
gezzuzz's Avatar
take the glove box out and look for the nut.. there is a bunch.. when you get them all out the air bag will come out easy
Old Jan 7, 2007 | 10:16 AM
ALL THE SCREWS ARE AND I AM PUSHING IT FROM THE BOTTOM BUT THE TOP IS NOT COMING OUT
Old Jan 7, 2007 | 10:18 AM
gezzuzz's Avatar
what car? year?
Old Jan 7, 2007 | 10:21 AM
96 SEDAN A LADY RAN A STOP SIGN AND YOU KNOW THE REST ...... IT SAY IT HAS 3 SCREW I TOOK THEM OUT BUT STILL NOTHIN
Old Jan 7, 2007 | 10:22 AM
CIVIC
Old Jan 7, 2007 | 10:29 AM
gezzuzz's Avatar
you right there is only 3 screws.. but around the air bad cover there are tabs that hold it to teh dash board. pry it up here with something flat and wooden like a paint stir stick.. and push up at the same time
Old Jan 7, 2007 | 10:30 AM
Default Re: AIR BAGS HELPPPPPP (gezzuzz)
THNX BE RIGHT BACK!!!!!!!!!!!!!!
Old Jan 7, 2007 | 10:44 AM
Eran's Avatar
HT White Ops
You need to take the glovebox completely off, take all the bolts out, unplug the harness, remove the top piece (it's holding the airbag in place).
PS - Please stop using capslock.
Old Jan 7, 2007 | 10:58 AM
PPRECC I'VE BEEN TRYING TO GET IT OUT FOR PAST 1HR 30MIKS THNX
Old Jan 7, 2007 | 04:23 PM
redsidriver's Avatar
the air bag has hooks all around connecting it to the air bag cover. once you get those hooks released its easy. it was easy for me becasue i had the whole dash out of the car
Old Jan 7, 2007 | 04:27 PM
gezzuzz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by caraudiofaq &raquo;</TD></TR><TR><TD CLASS="quote">PPRECC I'VE BEEN TRYING TO GET IT OUT FOR PAST 1HR 30MIKS THNX </TD></TR></TABLE>
as your see problem solved!!
Old Jan 7, 2007 | 04:44 PM
pkdog167's Avatar
use hack saw to cut it out
Old Jan 7, 2007 | 04:46 PM
bart2546's Avatar
Default Re: AIR BAGS HELPPPPPP (pkdog167)
Hmm, no one has said anything about caps lock yet...guess I'm the first. But with the rest of the posters, yes the 3 screws hold it as a main "lockdown" if you will but the tabs must be gently pried out unless it's deployed and then just rip the sucker out.
Old Jan 7, 2007 | 05:25 PM
Eran's Avatar
HT White Ops
Default Re: AIR BAGS HELPPPPPP (bart2546)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bart2546 &raquo;</TD></TR><TR><TD CLASS="quote">Hmm, no one has said anything about caps lock yet...guess I'm the first. But with the rest of the posters, yes the 3 screws hold it as a main "lockdown" if you will but the tabs must be gently pried out unless it's deployed and then just rip the sucker out. </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran &raquo;</TD></TR><TR><TD CLASS="quote">PS - Please stop using capslock.</TD></TR></TABLE>
bart2546's Avatar
Default Re: AIR BAGS HELPPPPPP (Eran)
**** you're right, my bad overlooked that.
oneEg1Tc
Dec 13, 2009 01:29 PM
RA102725
May 25, 2007 10:00 AM
CDN Yellow ITR
Dec 15, 2006 10:02 AM
imptricer
12
Jan 30, 2006 06:58 PM
gameovr
May 26, 2002 05:54 PM
