ITR or Suspension Technique rear sway bar???
I have a 94 ls integra and I can't decide on which sway bar to get so I wanted to ask around. I know the ITR rear sway bar is 23mm and ST's is only 19 but I was wondering if ST's is better because of the material used to make it. Haha I really have no idea but thanks for reading.
I have the JDM ITR sway bar install. Let you know. You need a bracket kit that you can buy over at Team-Integra.net. It's a pain the butt to install it.
Also a side note: I can hear the subframe twisting a little due to the 23mm sway bar.
i would go with the ST one. it may be smaller diameter but that may be due to different mounting points. my progress sway bar uses the shock mount bolts as opposed to the holes in the middle of the LCA. additionally if you go with the ST it will come with whatever brackets and reinforcement that you will need, whereas the itr you will need a bsq kit, beaks, or asr subframe brace.
dgdarien
10
Mar 30, 2003 01:09 PM
