4th gen shifter cables
Old Jan 7, 2007 | 09:49 AM
pprowler6's Avatar
Default 4th gen shifter cables
im connecting my shifter cables into my 4th gen for my swap and am wondering how they are supposed to be routed into the engine bay. pictures or discriptions any help would be great.
Old Jan 7, 2007 | 01:33 PM
98vtec's Avatar
moderator emeritus
Default Re: 4th gen shifter cables (pprowler6)
around the engine mount, under the intake manifold, bolt backet to rear crossmember, feed cables to the cabin, bolt cabin mount up, attach cables.
you will need to unbolt your heatshield and remove the center console to access the cabin mount.
Old Jan 7, 2007 | 06:19 PM
pprowler6's Avatar
Default Re: 4th gen shifter cables (B.Rabbit)
looking down at the engine what side of the rear engine mount? I hooked them up and have them traveling to the left of the rear engine mount looking down. Is this correct?
Old Jan 7, 2007 | 06:34 PM
98vtec's Avatar
moderator emeritus
if you are at the front of the car, looking down....they go to the right of the mount.
Old Jan 7, 2007 | 06:36 PM
pprowler6's Avatar
how the hell does that work. i dont see how they can fit and come across
Old Jan 7, 2007 | 09:19 PM
pprowler6's Avatar
can anybody back that up with some pictures on how they route?
Old Jan 7, 2007 | 09:29 PM
98vtec's Avatar
moderator emeritus
do you have the cables bolted to the bracket on top of the tranny. I just did this like 3 weeks ago so i know how they are supposed to be routed.
when you are putting the cables in, feed them through the engine bay. If you are standing on top of the motor and looking down you would make the cables go to the right of the rear mount. Then get under the car. You should already have the heatshield taken off from when you removed them. get the cables to come around the backside of the rear crossmember. You can then bolt the mount for the crossmember back into place. next, feed the ends inside the cabin. Push the mountup and bolt it in. the rest is cake.
Old Jan 7, 2007 | 11:24 PM
pprowler6's Avatar
well as u know its a pain in the *** the reach above the heat shield and put those 2 bolts in...i have the cables running on the left side of the engine mount. You think this is ok or should i move them to the right?
Old Jan 12, 2007 | 02:47 PM
92Luda's Avatar
Damn i think i have to replace mine soon as well. Anyone have any pics of this stuff?
mclasser
Aug 4, 2015 12:37 PM
jmanuel
Jul 8, 2014 11:47 PM
B18b Axles
Jun 22, 2012 08:19 AM
TheOdd001
Feb 17, 2010 05:02 AM
satan_srv
Nov 8, 2004 07:14 PM
