manual transmission swap wiring help
Old Jan 7, 2007 | 09:12 AM
pprowler6's Avatar
Default manual transmission swap wiring help
ok guys im finishing up my manual swap and am a little confused about the wiring that needs to be done. I have read the write-ups on honda-tech and a couple other forums with no such luck. The question is what really needs to be wired up the the clutch pedals. Im pretty sure the one switch is for cruise control and since i dont have that i wont need to hook anything up. Now the other switch is so the pedal has to be depressed to disengage the clutch do i need to wire that up or can i bypass it somehow. I think its just a matter of finding the correct wires to splice together. So i think i just need bypass that switch and hook up reverse lights. Can anybody that has done this in a 4th gen help me out. Thanks
Old Jan 7, 2007 | 06:19 PM
pprowler6's Avatar
Default Re: manual transmission swap wiring help (pprowler6)
come on fellas who has done the manual swap and can help me out?
Old Jan 7, 2007 | 06:41 PM
SteveoBA8's Avatar
my pos dvom
Here's what you can do
1. Solder the two large black/white wires together.
2. Wire up a relay with the two black/white and use the clutch switch.
3. Lengthen the two wires and run them to the switch.
I suggest #2
As for the reverse light's( i still need to hook mine up cuz im lazy)
This should be the reverse light wire.
Old Jan 7, 2007 | 06:47 PM
pprowler6's Avatar
so to start the engine all i would need to do is hook together the two big black wires? I need a little bit more explaining. thanks
Old Jan 7, 2007 | 06:57 PM
SteveoBA8's Avatar
Correct
Old Jan 7, 2007 | 07:02 PM
pprowler6's Avatar
Default Re: manual transmission swap wiring help (SteveoBA8)
u have some swett ms paint skills. but thanks hopefully have this up and running as by wednesday
Old Jan 7, 2007 | 07:05 PM
SteveoBA8's Avatar
No prob.
Old Jan 7, 2007 | 07:14 PM
mgags7's Avatar
steveo is right about the starter cut
run two wires to the reverse switch on the trans, then hook the yellow wire and the green one steveo pointed out to each of them, then your reverse lights will work
1993eg8_car
Jul 23, 2009 08:22 AM
JokerX-1.6T
Jun 8, 2007 05:08 PM
honda95civic
Audio / Security / Video
Dec 11, 2005 04:50 PM
Magick211
May 21, 2003 03:23 AM
