HELP!!! INSTALLING A D15Z1 OBD1 ENGINE INTO AN EK CIVIC DX OBD2 SHELL !!!
Old Jan 6, 2007 | 09:00 PM
gotboosthatch's Avatar
Default HELP!!! INSTALLING A D15Z1 OBD1 ENGINE INTO AN EK CIVIC DX OBD2 SHELL !!!
helppp!!!!!!!!
hey guys , can you help me out and let me know what I need to do so I can swap a d15z1 engine from a 95 vx hatch obd1 into my 98 civic dx obd2 ?? im just installing installing this motor so I can have a ride for awhile as a daily driver while my other hatch is gettin built.. let me know what I need to do about the wiring and stuff ..thanks
Old Jan 7, 2007 | 08:57 AM
Default Re: HELP!!! INSTALLING A D15Z1 OBD1 ENGINE INTO AN EK CIVIC DX OBD2 SHELL !!! (gotboosthatch)
anyone?????????? help?????????/
Old Jan 7, 2007 | 10:57 AM
97civicdx's Avatar
Doesnt the VX also have that 5 wire o2 sensor?
Old Jan 7, 2007 | 11:02 AM
Crasian's Avatar
yes it does, remember that the z1 doesnt have the crank sensor so to bypass that u would need an obd2 to obd1 harness and use the z1's ecu
Old Jan 7, 2007 | 12:03 PM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gotboosthatch &raquo;</TD></TR><TR><TD CLASS="quote">helppp!!!!!!!!
This is probably going to be more hassle than it's worth for a temporary solution.
Don't you have any other options? Can you just drive the VX? Pick up a D16Y7 (they're incredibly cheap)?
Old Jan 12, 2007 | 02:51 PM
where can i find an obd2&gt;obd1 harness? i already have both cars and dont wana spend anymore cash on them.. anymore help???
Old Jan 12, 2007 | 02:54 PM
Eran's Avatar
HT White Ops
It's going to be a PITA. I'd be a better alternative to do a D16Y5 swap.
Old Jan 12, 2007 | 04:06 PM
schardbody's Avatar
yeah, there isnt even a point in trying to swap it over, i mean, it wont run right unless you add a good bit of wiring and basically hack the crap out of the car. its more work than its worth in the end, especially if its just for temporary. do yourself a favor and pick up ANYTHING obd2.
Old Jan 12, 2007 | 05:06 PM
Bense's Avatar
man this is going to be so much of a pain in the ***, just put it in and run it off of the stock ecu, and set base timing to like 5
it will run like ****, but who cares, i wouldn't wire **** up. I'd put the stock dx dizzy on with vice grips if you have to. **** egr, 5wire, vtec, and knock sensor, who cares. I would say not to rev that engine beyond 6000rpms, but you will have such **** for power, that you won't be able to, even in neutral.
hahhaa
Old Jan 12, 2007 | 05:55 PM
could i just buy the obd2 &gt; obd1 conversion harness? and use the obd1 z1 ecu?
Old Jan 12, 2007 | 05:59 PM
schardbody's Avatar
Default Re: (gotboosthatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gotboosthatch &raquo;</TD></TR><TR><TD CLASS="quote">could i just buy the obd2 &gt; obd1 conversion harness? and use the obd1 z1 ecu?</TD></TR></TABLE>
like i said if you have to ask the answer is NO. simply put there are atleast 3 connectors and 10 more wires you have to run to the ECU itself to get it to work HALF ASSED.
JUST SPEND THE $100 on another longblock.
Old Jan 12, 2007 | 06:26 PM
anyone have a bottom end for a d16y7???
Old Jan 12, 2007 | 07:40 PM
could i just use the d15 block with my d16y7 head??? let me know..thanks
Old Jan 13, 2007 | 11:41 AM
???????????????? help??????????????
Old Jan 13, 2007 | 12:55 PM
schardbody's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gotboosthatch &raquo;</TD></TR><TR><TD CLASS="quote">could i just use the d15 block with my d16y7 head??? let me know..thanks</TD></TR></TABLE>
NO, the outcome would be more of a headache. quit being cheap and buy a motor or rebuild yours.
Old Jan 13, 2007 | 03:52 PM
Default Re: (schardbody)
cheap?? wtf u talkin about?? im fully building a k20????????
if you dont have anything helpful to say dont post it here...
anyone else????
Old Jan 13, 2007 | 04:08 PM
Eran's Avatar
HT White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gotboosthatch &raquo;</TD></TR><TR><TD CLASS="quote">cheap?? wtf u talkin about?? im fully building a k20????????
anyone else????</TD></TR></TABLE>
So you're fully building a K20 .... but you don't know the complications involved with putting a VX motor in an OBD2 car?
BEEEEE-ESSSSS.
Old Jan 13, 2007 | 05:50 PM
schardbody's Avatar
the info i posted is HELPFUL. by the way, i seriously doubt you are building a K if you cannot answer your own question at hand. especially the "can i use the vx shortblock with the y7 head."
Old Jan 13, 2007 | 07:56 PM
believe what u want... i seriously am though..
you can use a d15 block with a d16 and make a minime swap.. i might do that...
i found a d16 shortblock for $150.. i might just grab that up and put the stock d16y7 head on it and be done with it..
i was just askin a question since i dont know d series..
thanks though
Old Jan 14, 2007 | 05:55 AM
schardbody's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gotboosthatch &raquo;</TD></TR><TR><TD CLASS="quote">believe what u want... i seriously am though..
thanks though</TD></TR></TABLE>
you sure can, but not with a d15z1 stock pistons, well actually you still can, you wont be happy though, compression is like 7.8:1 when you are done.
Old Jan 14, 2007 | 01:59 PM
alright.. thanks guys.. just asking some questions.
Old Jan 14, 2007 | 02:38 PM
Bense's Avatar
If you're trying to use a 14mm wrench, on a 10mm bolt, what are you going to do?
Old Jan 14, 2007 | 04:05 PM
Eran's Avatar
HT White Ops
Default Re: (Bense)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bense &raquo;</TD></TR><TR><TD CLASS="quote">If you're trying to use a 14mm wrench, on a 10mm bolt, what are you going to do?</TD></TR></TABLE>
Swear a lot?
Old Jan 14, 2007 | 04:10 PM
Bense's Avatar
get a 10mm wrench, instead of trying to make a 14mm into something it's not
gotboosthatch
May 29, 2008 12:19 PM
Creepsjr
15
Oct 29, 2007 12:36 PM
iLUVmyHONDAcura
Jul 16, 2005 09:58 PM
S4gasm
Oct 31, 2004 08:27 AM
airon
Jun 12, 2001 03:09 PM
