coolant leak on drivers side - waterpump?
Old Jan 6, 2007 | 04:44 PM
b18c4door's Avatar
Default coolant leak on drivers side - waterpump?
1998 GS-R, 87K miles....T-belt not done yet...
Wife says garage floor has coolant, come back and check - sure enough, coolant puddle on drivers side. So, after jacking it up, I see the oil pan lip on the block has coolant and is dripping off there. I checked to see if its leaking at the head and doesnt seem to be...
I am guessing water pump or the o-rings? I also read it could be a seal inside the timing cover,
This happen to anyone else and if so, what was the issue?
Should I replace the t-belt and the pump - Figured its better to do it this way?
Any advice appreciated! Thanks!
Old Jan 6, 2007 | 04:45 PM
shyboy817's Avatar
Happened to me. Started leaking. Then started to cause overheating issues. Surely enough it was my waterpump... I had the water pump and timing belt changed at the same time.
Old Jan 6, 2007 | 08:53 PM
dc5_integra's Avatar
Default Re: (shyboy817)
Yes you should always replace the timing belt at the same time as the water pump. Just to keep it all up to snuff and so you dont have to open it all back up again. Also there interference engines so you want make sure that you have a good belt on there.
Old Jan 6, 2007 | 10:33 PM
b18c4door's Avatar
Default Re: (dc5_integra)
Thanks, guys. I will do it with only genuine honda parts...This mechanic I know is that way. He won't let me use anything else, even aftermarket like greddy belt if I wanted him to.
Old Jan 7, 2007 | 11:09 AM
Default Re: (b18c4door)
I would go oem too. The car knows nothing better then oem.
Old Jan 7, 2007 | 03:02 PM
b18c4door's Avatar
I hear that gates makes the OEM Belts and I found a gates racing belt on ebay - I wonder if that would be advisable
Old Jan 7, 2007 | 03:41 PM
dcRay's Avatar
Water pumps tend to go bad if you let your car sit too long without driving it. I went through two oem water pumps on my prelude within one year.
Old Jan 7, 2007 | 07:20 PM
b18c4door's Avatar
Default Re: (dcRay)
Well, it has 87K on it and the guy who owned it used it as a daily driver from day 1 when he bought it. I got all maintainence reciepts and none mention a leak etc...2 weeks after I get it and leaking seems to have begun
Old Jan 7, 2007 | 08:21 PM
shyboy817's Avatar
80-90k is when you tend to need to change your water pump / timing belt anyways. Unless the guy had the receipt to it that was recently done. Go OEM they are not that expensive.
Old Jan 8, 2007 | 03:41 AM
b18c4door's Avatar
I am calling today. I also seem to have an oil leak - oil pan gasket perhaps!
Oh - and to answer your question: I asked him about t-belt and he said owners manual said it required no maintainence till 100K and that the t-belt was listed at 105K miles.
He was a 45 year old guy who bought it brand new in 1998 and just drove it daily. He even gave me a set of winter tires he would get swapped out every winter. Kinda nuts. I just wish he had got leather - he doesnt like leather, I guess!
Modified by b18c4door at 7:38 AM 1/8/2007
Old Jan 8, 2007 | 06:59 AM
b18c4door's Avatar
Decided to go with the OEM kit....Hopefully, I can get it done tomorrow. Maybe the oil leak can be addressed too. Wish me luck!
Old Jan 8, 2007 | 07:23 AM
shyboy817's Avatar
Well would you rather pay labor twice or once? You do water pump / timing belt at same time because they're in the same area and takes no extra labor to change the timing belt while at it. You can pay for labor twice within 2months if you want. And it might say it at 100k, but I think people still change it out 80-90k just in case something happens before hand.
Old Jan 8, 2007 | 07:42 AM
b18c4door's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shyboy817 &raquo;</TD></TR><TR><TD CLASS="quote">Well would you rather pay labor twice or once? You do water pump / timing belt at same time because they're in the same area and takes no extra labor to change the timing belt while at it. You can pay for labor twice within 2months if you want. And it might say it at 100k, but I think people still change it out 80-90k just in case something happens before hand.</TD></TR></TABLE>
I agree totally with you, don't know if I confused you somehow -
I meant I am doing the timing belt and water pump (getting the OEM kit). Actually, I am also changing the oil (500 miles overdue), valve cover gaskets, thermostat and radiator flush. If the oil pan gasket is leaking, I am swapping it out too. I am also have the crank pulley seal checked out to make sure it is not leaking oil and will have that replaced too, if needed.
Anything else you can think of to get checked when I am down there?
tag0617
Apr 17, 2011 11:09 PM
Lude-Lee
Feb 18, 2008 07:50 PM
hillbillybob
Jun 17, 2004 10:15 PM
Seye
Mar 28, 2004 03:26 PM
Sephro
Mar 20, 2003 11:19 AM
