**PIC Bearing worn funny?
Old Jan 6, 2007 | 03:59 PM
Ahks's Avatar
Default **PIC Bearing worn funny?
EDIT: these are the rod bearings
is this abnormal? if so what would cause it?
and sorry for crap quality
Modified by Ahks at 8:16 PM 1/6/2007
Old Jan 6, 2007 | 04:00 PM
dohcVTECeg2's Avatar
Default Re: **PIC Bearing worn funny? (Ahks)
i cant see ****.
but you did just blind the **** outta me
Old Jan 6, 2007 | 04:32 PM
Hybrid-Fusion's Avatar
Default Re: **PIC Bearing worn funny? (dohcVTECeg2)
Yeah, you can see copper... that is worn weird.
Old Jan 6, 2007 | 04:48 PM
Ahks's Avatar
Default Re: **PIC Bearing worn funny? (Hybrid-Fusion)
thats what i was thinking...
Old Jan 6, 2007 | 06:20 PM
Ahks's Avatar
I need to know if this is gonna be a problem later... and what to do to fix it if it is.
Old Jan 6, 2007 | 06:52 PM
Joe_98Si's Avatar
just replace you bearings now, dont wait for a problem down the road
Old Jan 6, 2007 | 07:19 PM
Ahks's Avatar
Default Re: **PIC Bearing worn funny? (Joe_98Si)
i am... i'm rebuilding the engine... i'm trying to figure out if the abnormal wear will result in another rebuild in 50k miles
Old Jan 6, 2007 | 09:18 PM
Mr HYDE's Avatar
looks a little thin. you shouldnt really see bronze but i can barley tell from the picture. you wore it to thin anymore driving and it will spin or ruin your crank
Old Jan 6, 2007 | 09:20 PM
egmatt93's Avatar
Default Re: **PIC Bearing worn funny? (Mr HYDE)
just replace it whiles the motors apart dude
Old Jan 6, 2007 | 09:39 PM
Ahks's Avatar
Default Re: **PIC Bearing worn funny? (egmatt93)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Joe_98Si &raquo;</TD></TR><TR><TD CLASS="quote">just replace you bearings now, dont wait for a problem down the road</TD></TR></TABLE>
AND
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ahks &raquo;</TD></TR><TR><TD CLASS="quote">i am... i'm rebuilding the engine... i'm trying to figure out if the abnormal wear will result in another rebuild in 50k miles</TD></TR></TABLE>
so... I am replacing the bearings now. but...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ahks &raquo;</TD></TR><TR><TD CLASS="quote">i'm trying to figure out if the abnormal wear will result in another rebuild in 50k miles</TD></TR></TABLE>
Old Jan 6, 2007 | 09:59 PM
MasterKwan's Avatar
Looks to me like it was either run low on oil or it was put together tight some time in the past.
Old Jan 6, 2007 | 11:32 PM
Ahks's Avatar
Default Re: **PIC Bearing worn funny? (MasterKwan)
cool... as long as it doesnt indicate an issue with hard parts.
Old Jan 6, 2007 | 11:39 PM
Minglor's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MasterKwan &raquo;</TD></TR><TR><TD CLASS="quote">Looks to me like it was either run low on oil or it was put together tight some time in the past. </TD></TR></TABLE>
agree.
Old Jan 7, 2007 | 04:50 AM
GarageAlchemist
Guest
Posts: n/a
Default Re: **PIC Bearing worn funny? (Minglor)
just a guess, the worn marks on the bearings are at the end of the bearing, could be something
Old Jan 7, 2007 | 06:44 AM
MasterKwan's Avatar
Default Re: **PIC Bearing worn funny? (GarageAlchemist)
Yeah, if you're really worried you ought to let a machine shop measure the rods and make sure the block alignment's correct.
norcalB18
Feb 15, 2016 04:48 PM
1HGEJ2
Apr 28, 2014 11:25 AM
FRU
Nov 8, 2008 06:01 PM
steinar
Apr 8, 2006 09:10 PM
GaRn
Dec 30, 2005 10:57 PM
