95 civic w gsr swap having trouble with main relay
Old Jan 6, 2007 | 02:08 PM
imports07's Avatar
Default 95 civic w gsr swap having trouble with main relay
i have a 95 civic w a 98 gsr swap my main relay isnt turning on i changed the relay out and still didint work so i changed the distributor fuel pump and gave the car a full tune up and the car wont start unless i jump the relay but for some reason my ecu blew so i had to replace it does anybody have any help thanks pat
and when the car is running its holdin back when the check engine light is on but if i try to peel out the check engine light shuts off and the car got pull
Old Jan 6, 2007 | 02:46 PM
Throwdown's Avatar
From: CAPITAL CITY Tallahassee D.S., Florida, U.S.A
Default Re: 95 civic w gsr swap having trouble with main relay (imports07)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by imports07 &raquo;</TD></TR><TR><TD CLASS="quote">
and when the car is running its holdin back when the check engine light is on but if i try to peel out the check engine light shuts off and the car got pull</TD></TR></TABLE> WTF? did you just do this swap and or has it been running before fine then started having "these" problems?
Old Jan 6, 2007 | 03:25 PM
imports07's Avatar
Default Re: 95 civic w gsr swap having trouble with main relay (Throwdown)
i had the car for 3 mon and then it started to act up
mkhalid8
Jan 31, 2015 01:11 PM
Timmyflys
Nov 29, 2006 04:26 AM
7808
Jul 20, 2004 09:14 PM
irev210
Jun 11, 2003 07:00 PM
