IGNITION SWITCH? CAN I USE A AUTO ON A MANUAL? OR A MANUAL ON A AUTO?
Old Jan 6, 2007 | 11:37 AM
philosofy1's Avatar
Default IGNITION SWITCH? CAN I USE A AUTO ON A MANUAL? OR A MANUAL ON A AUTO?
well, lately my car is having starting problems. i have already replaced ground wires, battery, starter, alternator, battery terminals. the only thing i can think of next is ignition switch.
called the dealer up and the want $300 for the whole ignition/ke lock assembly.
the local parts store are not to far behind. neither sells the seperate.
since i only need the switch itself and not the lock nor the lock cylinder, i have found some on ebay. but most of them are for manual cars. since mine is a automatic, can i use a manual one in my car?
will it cause complication later on down the road?
is it a straight plug n play? or do i have to modify the harness?
Old Jan 6, 2007 | 11:55 AM
philosofy1's Avatar
Default Re: IGNITION SWITCH? CAN I USE A AUTO ON A MANUAL? OR A MANUAL ON A AUTO? (philosofy1)
bump
Old Jan 6, 2007 | 12:14 PM
philosofy1's Avatar
also, why acura is able to sell the switch seperate from the lock cylinder and honda dosen't? and can i use one from an interga, being that it's sold seperate?
Old Jan 7, 2007 | 02:06 AM
philosofy1's Avatar
hello?
Old Jan 7, 2007 | 06:25 AM
dem0nk1d's Avatar
i think it should be the same... check honda, and see if there is different part numbers. if the numbers are the same, then they are the same...
Old Jan 7, 2007 | 06:43 AM
Eran's Avatar
HT White Ops
I've got a 6G civic ignition wire I can sell you for pretty cheap. Got some key cylinders too.
Modified by Eran at 9:52 AM 1/7/2007
Old Jan 7, 2007 | 08:13 AM
Luserkid's Avatar
Default Re: (Eran)
I believe if you only get the cylinder youll be ok. Its the wiring that allows you to pull the key out and turn on. The cylinder locks the key/wheel though.
travbrack
Aug 3, 2010 03:17 PM
vsm_EJ6
Mar 20, 2009 08:53 PM
swg111789
Oct 4, 2006 09:17 PM
mingchi69
Feb 5, 2004 04:32 PM
