CAR BOGS, please help!!!
Old Jan 6, 2007 | 08:48 AM
Japanda's Avatar
Default CAR BOGS, please help!!!
so, last night we just finished a b16a swap into my 1993 hatchback. the car is drivable but when i try to push it into higher rpm, it'll bog. i am running with d15 fuel injectors because the b-series ones were broken. there is a knock sensor code, but i don't think thats it, there was a problem with the car starting also, i sometimes would try to start the car and all i could hear is the crank but no start, so i take the dizzy cap off and clean it a little and it starts, and sometimes it doesn't, so i'm having a feeling that little clue could also connect with my bogging issue???
Modified by Japanda at 3:35 PM 3/6/2007
Old Jan 6, 2007 | 08:55 AM
cherryhatch00's Avatar
For starters, you're more than likely not getting anywhere near enough fuel, although I don't want you to quote me on that because I dunno what the average d15 is given as far as fuel. But, the knock sensor code SHOULD be looked into. I don't think that's it, but it should definitely be looked at.
Btw, are you running small exhaust? When I did a b18c5 swap on a '92 cx hatch with mostly stock exhaust components (still had the catalytic convertor), whenever vtec would engage it would cork the exhaust flow and I'd get practically no power. Driving around town under 4500 rpm it was good, but if you got VTEC to engage then it'd bog severely. Sound something like what you're talking about, or?
Old Jan 6, 2007 | 09:01 AM
Japanda's Avatar
Default Re: (cherryhatch00)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cherryhatch00 &raquo;</TD></TR><TR><TD CLASS="quote">For starters, you're more than likely not getting anywhere near enough fuel, although I don't want you to quote me on that because I dunno what the average d15 is given as far as fuel. But, the knock sensor code SHOULD be looked into. I don't think that's it, but it should definitely be looked at.
Btw, are you running small exhaust? When I did a b18c5 swap on a '92 cx hatch with mostly stock exhaust components (still had the catalytic convertor), whenever vtec would engage it would cork the exhaust flow and I'd get practically no power. Driving around town under 4500 rpm it was good, but if you got VTEC to engage then it'd bog severely. Sound something like what you're talking about, or?</TD></TR></TABLE>
YES! as i get around that rpm, it would sound like it wants to push more power but it can't and starts bogging. i am running the dx exhaust set-up, all stock componenst besides a universal exhaust tip. so this means new exhaust?
Old Jan 6, 2007 | 09:25 AM
Japanda's Avatar
Default Re: (Japanda)
bump. more help please???
Old Jan 6, 2007 | 09:51 AM
bigl1986's Avatar
i would check the fuel injectors for sure. or how about the fuel filter??? have you changed that recently. that could make a big diffrence! but there is also the fact the knock is bad
Old Jan 6, 2007 | 10:04 AM
allricedout's Avatar
also be sure to replace the fuel pump filter too....
Old Jan 6, 2007 | 10:11 AM
sal's Avatar
sal
Default Re: (allricedout)
If im not mistaken, im pretty sure the single cam injectors are 240's... and the b16 injectors are also 240's...
Old Jan 6, 2007 | 03:45 PM
Hybrid-Fusion's Avatar
Default Re: (sal)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sal &raquo;</TD></TR><TR><TD CLASS="quote">If im not mistaken, im pretty sure the single cam injectors are 240's... and the b16 injectors are also 240's...</TD></TR></TABLE>
That's right. They are the same size.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allricedout &raquo;</TD></TR><TR><TD CLASS="quote">also be sure to replace the fuel pump filter too....</TD></TR></TABLE>
You mean the fuel filter. Don't worry about the fuel pump. There's people in the 12's all motor without an upgraded pump.
It may be the with a knock sensor code the car's timing maps are retarded and it's in a limp home mode in the first place. What ECU are you running?
Old Jan 6, 2007 | 08:58 PM
Japanda's Avatar
Default Re: (Hybrid-Fusion)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid-Fusion &raquo;</TD></TR><TR><TD CLASS="quote">
It may be the with a knock sensor code the car's timing maps are retarded and it's in a limp home mode in the first place. What ECU are you running?</TD></TR></TABLE>
currently usuing P30 ECU. during the swap, my friend broke the knock sensor.
Old Jan 8, 2007 | 10:33 AM
Japanda's Avatar
bump, i seems that this morning, my car won't start, you can hear it cranking but it won't start, so i'm leaning torwards that the distributor is causing this ****. what do u guys thinks?? help plz!
Old Jan 9, 2007 | 08:47 AM
Japanda's Avatar
bump, need help!
Old Jan 9, 2007 | 09:04 AM
blue_hatch's Avatar
its not your injectors... b16 d15 both use 240 injectors. im guessing it has to to with your timing or your dizzy. try correcting the timing.
Old Jan 9, 2007 | 10:34 AM
sal's Avatar
sal
Default Re: (blue_hatch)
It could be one of many things, for starters you might want to get rid of all you check engine lights. From what your describing it also sounds like the timing belt might be off a tooth, try going over those things and let me know how it goes..
Old Mar 6, 2007 | 02:32 PM
Japanda's Avatar
Default Re: (sal)
bump, still having this problem, its been a while yes, but i haven;t had a chance to fix my car. right now, i am having a strong feeling it could be my distributor
Old Mar 8, 2007 | 03:02 PM
Japanda's Avatar
help plz???
amnbassist
Dec 2, 2011 09:24 AM
rollinhonda3
Jun 19, 2011 02:55 PM
Wakes4Fun
Nov 23, 2010 07:01 AM
jdmpremonition
13
Feb 24, 2006 10:37 AM
GSRWSU
Aug 21, 2005 10:27 AM
