f22a1 wiring harness
Old Jan 6, 2007 | 08:16 AM
mixmastermatt's Avatar
Default f22a1 wiring harness
does anyone know if the f22a1 wiring harness is differnet from the h23a1 wiring harness
Old Jan 6, 2007 | 01:29 PM
SteveoBA8's Avatar
Default Re: f22a1 wiring harness (mixmastermatt)
Yep. The f22a1 engine harness can be used on an H23/22 if you extend the o2 sensor and oil pressure wires iirc.
The H23 and H22 harness's are the same except the H23 harness lacks vtec wiring which can be added easily.
Search archived content
Old Jan 6, 2007 | 02:00 PM
prelittlelude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mixmastermatt &raquo;</TD></TR><TR><TD CLASS="quote">does anyone know if the f22a1 wiring harness is differnet from the h23a1 wiring harness </TD></TR></TABLE>
i belive the f22 harness also lacks the knock sensor wires..
Old Jan 6, 2007 | 03:10 PM
SteveoBA8's Avatar
Default Re: f22a1 wiring harness (prelittlelude)
oops, yep no ks on the f22a1.
Old Jan 18, 2007 | 07:45 AM
skylude23's Avatar
i have an h23 and im dropping an h22 i have the p13 ecu .you say the vtec wires are easy to run can you please tell how to wire it up. which pin and color wire etc.
Old Jan 18, 2007 | 07:50 AM
skylude23's Avatar
Default Re: f22a1 wiring harness (skylude23)
oh yeah i also heard that the j-spec p13 ecu has a governer that cuts fuel off at 118 mph is that true
Old Jan 18, 2007 | 08:10 AM
Hawkze_2.3's Avatar
Barely ever get to use this pic
KidFrost
Feb 18, 2009 07:48 PM
bmayer
Jul 4, 2008 05:26 AM
93PreludeF22
May 15, 2007 12:42 PM
obeyyourlude
Apr 14, 2005 10:32 AM
humtake
May 20, 2003 04:46 AM
