location of FITV on D15B1
Old Jan 6, 2007 | 07:19 AM
G60's Avatar
G60
Default location of FITV on D15B1
Still having a surging idle problem. Took the EACV off my old motor and put it on the new same, same problem. No CEL. I guess the FITV is the next place to check for a problem, can someone tell me where it is and what it looks like? I know it should be on the back of the TB someplace, any more specific?
Old Jan 6, 2007 | 07:20 AM
Boosted Chemist's Avatar
Default Re: location of FITV on D15B1 (G60)
it usually has a coolant hose going to it. You should take it apart and screw the plunger back into it. This will sovle the idle problems. THE FITV is like 1.5"x 4" in size.
Old Jan 6, 2007 | 07:49 AM
jlicrx's Avatar
D15B1 does not have a FITV
Old Jan 6, 2007 | 08:08 AM
G60's Avatar
G60
Default Re: location of FITV on D15B1 (jlicrx)
Ah, that explains why I'm su friggin confused staring at the motor, thinking "where the hell is this thing?"
So, I changed over the EACV, there's no FITV to check, what else could be causing my suring idle?
Old Jan 6, 2007 | 08:31 AM
jlicrx's Avatar
surging idle usually caused by bad EACV, faulty coolant temp sensor for the ECU or low coolant level (or trapped air) in the cooling system - could also be vacuum leak
Old Jan 6, 2007 | 09:55 AM
G60's Avatar
G60
Well, figured out my problem. When I changed over the TB from the old motor to the new one, forgot that plastic plate underneath it with the gasket attached to it. Must have been leaking badly right below the TB, because I put it on there, runs great now.
B*Goods*EJ2
May 3, 2010 07:15 PM
entityzero
Mar 26, 2007 07:44 PM
calinomad
Oct 1, 2006 04:41 PM
ek_chris
Sep 21, 2006 11:15 AM
swads21
Jul 3, 2006 06:38 AM
