rod and main bearings... help please!
I'm rebuilding my bottem end soon and i need some help with a bearing issue. I usually use honda bearings, but they are like 225 for all of em. yet i can get acl's for ALOT cheaper. My question is how do i size them? Do I just buy Std. and call it good? If anybody has ANY info or has ran these bearings before, please let me know.
I would like to know too. I see alot of people list ACLs as the bearings they used. How do you know what size? How do they hold up?
i bought standard size acl's as a starter kit, because they're so cheap.... after i plastigauged every single one, it turned out that they were all within factory specs. my motor was in remarkable shape when i tore it down so you may not be so lucky.
i say get the acl's, then if you find a few clearances that are out of whack, go buy those individually from honda....spend a little time, save a little money.
so far i have about 1000 miles on my build and 0 problems
^ true, acl arent a bad bearing, i guess im just the 1% where none of my bearing where green. They all where red and pink. In mycase it would of been a waste
and you'll be more apt to need red or pink if you're building a race engine (or for boost) because they'll give you more oil clearance.....your parts will wear - and likely fail - faster, but then again a purpose built race car shouldn't be a daily driver
hardcore engine builders will tell you "loose is fast"
thanks a bunch you guys thats exactly what i was looking for. my bottem end is g y g g g and rods are all yellow. do you think that i could polish the yellows enough to get sufficient clearance for the acl's?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mahatma »</TD></TR><TR><TD CLASS="quote">and you'll be more apt to need red or pink if you're building a race engine (or for boost) because they'll give you more oil clearance.....your parts will wear - and likely fail - faster, but then again a purpose built race car shouldn't be a daily driver
hardcore engine builders will tell you "loose is fast"</TD></TR></TABLE>
my clearances are all within honda specs, accually on the tight side. MY manley rods where just on the tight side.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bevenue »</TD></TR><TR><TD CLASS="quote">thado you think that i could polish the yellows enough to get sufficient clearance for the acl's? </TD></TR></TABLE>
No, that is recipe for a spun bearing. Just use the correct bearing. Honda bearings are some of the best mass produced bearings in the world, maybe ever.
While on this topic, I have ACL's, and haven't plastiguaged it yet. The colors weren't visible when I pulled it apart, is there a size chart that would allow me to order the proper sized bearings if the ACL's don't get me within tolerance?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by danmdevries »</TD></TR><TR><TD CLASS="quote">While on this topic, I have ACL's, and haven't plastiguaged it yet. The colors weren't visible when I pulled it apart, is there a size chart that would allow me to order the proper sized bearings if the ACL's don't get me within tolerance?</TD></TR></TABLE>
on a b series you use the block letters + the number on the crank to give the size. Lets say for main #1 you have b2 (or 2b i forget) then u goto a helms and it gives the color. It works the same for the rods also. IF you build a motor with aftermarket rods and or line bored mains. You get a random bearing and plastigauge it and go up or down as needed.
