wrong size rear lower tie bar?
this is ebay-**** dont flame me http://cgi.ebay.com/ebaymotors...d=1,1
i have two lower tie bars left to put on
one has a bend to clear my exhaust/oil pan/ect. and that looks as if it'll fit the front fine.
the final is straight but slightly shorter, actually too short it seems
the bent one looks as if it would fit the rear too but im almost certain it's for the front
when i lift the car will it then be able to fit or is it simply the wrong size?
the one that has a bend goes on the front lower.
the one that goes straight goes on the rear lower.
if the bars don't fit your car the company may have sent you the wrong one. keep in mind those cheap bars are made to adjust on the ends.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dafuzzbudd »</TD></TR><TR><TD CLASS="quote">this is ebay-****</TD></TR></TABLE>
I stopped reading right here.
The bent one goes under the oil pan (and when you change your oil, it'll splash all over it, bonus .... 10 points). The straight one bolts onto the the inner rear LCA bolts. If it seems just a little too short, unthread the links so it's wider.
