Transmission Noise! Not gear grind!
Old Jan 5, 2007 | 09:21 PM
Hybrid-Fusion's Avatar
Default Transmission Noise! Not gear grind!
I have a '99 EX 5-speed. There is a noise when I let out the clutch. It seems to go through the same series of "chattering whining" in every gear. If I let the clutch out in neutral it stilll makes the noise. As soon as I press the clutch pedal the noise goes away.
What do you think it could be?
Old Jan 5, 2007 | 09:51 PM
Hondacivic90ed's Avatar
Default Re: Transmission Noise! Not gear grind! (Hybrid-Fusion)
Input shaft bearing
Old Jan 5, 2007 | 10:03 PM
Eran's Avatar
HT White Ops
ISB.
Old Jan 5, 2007 | 10:45 PM
ridin98civic's Avatar
yup, been driving with that problem for over a year
Old Jan 6, 2007 | 12:24 AM
1992 civic Jdm BOY's Avatar
Default Re: Transmission Noise! Not gear grind! (Hondacivic90ed)
is that the same as the pilot bearing
Old Jan 6, 2007 | 01:34 AM
Richard...'s Avatar
Default Re: Transmission Noise! Not gear grind! (1992 civic Jdm BOY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1992 civic Jdm BOY &raquo;</TD></TR><TR><TD CLASS="quote">is that the same as the pilot bearing</TD></TR></TABLE>
no pilot is to do with the clutch the input shaft is in the trans
Old Jan 6, 2007 | 02:37 AM
B18CivicEH2's Avatar
Default Re: Transmission Noise! Not gear grind! (richard7968)
mine did a similar noice when i had my d series, after swaping it out, noticed my throwout bearing was all messed up....could be it..
Old Jan 6, 2007 | 03:39 AM
EE_Chris's Avatar
Default Re: Transmission Noise! Not gear grind! (B18CivicEg)
If it's not the ISB, then it could be the bearing at the opposite end of the same shaft. BOTH were bad on my '99 D16Y7 tranny. The bearing...just the single *****...each one had pieces of it's 'shell' missing. So the ***** weren't smooth and shiny at all and it caused the car to shutter and make all sorts of nasty *** noises on take-off and getting up to speed.
Push in the clutch and the noise instantly died down. Not a hard fix, but two people (and a Helms) are needed.
Old Jan 6, 2007 | 06:03 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18CivicEg &raquo;</TD></TR><TR><TD CLASS="quote">mine did a similar noice when i had my d series, after swaping it out, noticed my throwout bearing was all messed up....could be it..</TD></TR></TABLE>
I figured the throw out bearing would only make noise when the clutch is pressed in since that's when it's loaded...
Old Jan 6, 2007 | 03:56 PM
Default Re: Transmission Noise! Not gear grind! (EE_Chris)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EE_Chris &raquo;</TD></TR><TR><TD CLASS="quote">If it's not the ISB, then it could be the bearing at the opposite end of the same shaft. BOTH were bad on my '99 D16Y7 tranny. The bearing...just the single *****...each one had pieces of it's 'shell' missing. So the ***** weren't smooth and shiny at all and it caused the car to shutter and make all sorts of nasty *** noises on take-off and getting up to speed.
Push in the clutch and the noise instantly died down. Not a hard fix, but two people (and a Helms) are needed.</TD></TR></TABLE>
Yeah, that's sounds very close to what I am experiencing. Any other takers?
Old Jan 6, 2007 | 04:55 PM
Runnerdown's Avatar
Yeah, its input shaft bearing(s) This is way too common on these trannys.
Old Jan 6, 2007 | 05:38 PM
Default Re: Transmission Noise! Not gear grind! (Runnerdown)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Runnerdown &raquo;</TD></TR><TR><TD CLASS="quote">Yeah, its input shaft bearing(s) This is way too common on these trannys.</TD></TR></TABLE>
Dammit. This is the first time I've heard of it!
Old Jan 6, 2007 | 05:39 PM
DohcSide's Avatar
learn something new everyday
Old Jan 6, 2007 | 06:21 PM
premier_ek9's Avatar
Default Re: Transmission Noise! Not gear grind! (DohcSide)
my d16y7 tranny does the same thing. i put in a new clutch, pressure plate and thorw out bearing then the car did it louder!!
Old Jan 6, 2007 | 06:46 PM
Bense's Avatar
without even reading, i'm betting it's the ISB
Old Jan 6, 2007 | 06:51 PM
YoungKadafi's Avatar
without even reading anything, ISB
Old Jan 6, 2007 | 08:25 PM
97civicdx's Avatar
Default Re: (YoungKadafi)
How difficult is it to replace the bearings on the d series trans? My trans Y7 is also ISB whining.
Old Jan 6, 2007 | 08:52 PM
Bense's Avatar
about as difficult as it is to not stick your dick in an oven
Old Jan 6, 2007 | 09:17 PM
egmatt93's Avatar
Default Re: (Bense)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bense &raquo;</TD></TR><TR><TD CLASS="quote">about as difficult as it is to not stick your dick in an oven</TD></TR></TABLE>ROFL
Old Jan 6, 2007 | 09:37 PM
hspoon's Avatar
SAME THING IS HAPPENING TO MY CAR... BUT I DONT HAVE ANY PRESSURE IN MY CLUTCH.... MY HOMEBOY TOLD ME ITS THE THROW OUT BEARING.... U THINK THAT COULD BE IT???
Old Jan 6, 2007 | 10:57 PM
Richard...'s Avatar
Default Re: (hspoon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97civicdx &raquo;</TD></TR><TR><TD CLASS="quote">How difficult is it to replace the bearings on the d series trans? My trans Y7 is also ISB whining. </TD></TR></TABLE>
if you can take the trans off your car should be fine!
just make sure and get your self the bearing remover tools and then all you gotta do is press one back on there wood and a hammer always serves me but thats me lol
Old Jan 6, 2007 | 11:10 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hspoon &raquo;</TD></TR><TR><TD CLASS="quote">SAME THING IS HAPPENING TO MY CAR YOU SOB... BUT I DONT HAVE ANY PRESSURE IN WTF STFUNOOB!.... MY HOMEBOY TOLD ME ITS MY SON OF A THROW OUT BEARING.... U THINK THAT COULD BE IT YOU AHOLE???</TD></TR></TABLE>
Seriously dude what did we ever do to you? or your family? relax
Old Jan 6, 2007 | 11:14 PM
Richard...'s Avatar
i think some should call an ambulance someone is having a break down lol
Old Jan 7, 2007 | 09:17 AM
hspoon's Avatar
HAHAHA....
NA SAME THING HAPPENED TO ME... BUT I DONT HAVE ANY PRESSURE IN MY CLUTH PEDAL... MY HOMEBOYS CAR DID THE SAME NOISE AND IT WAS THE THROW OUT BEARING..... YALL THINK THAT COULD BE WRONG WITH MY CAR???? RIGHT NOW I GOT A CHEAPASS CLUTH KIT FORM AUTOZONE...
THANX... AND IM SORRY FOR THE FIRST POST..... I WAS IN A HURRY...
Old Jan 7, 2007 | 09:35 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hspoon &raquo;</TD></TR><TR><TD CLASS="quote">HAHAHA....
THANX... AND IM SORRY FOR THE FIRST POST..... I WAS IN A HURRY...</TD></TR></TABLE>
When you don't have any pressure in a clutch pedeal it's usually the slave cylinder, pressure plate, or BADLY TOASTED throwout bearing (not likely).
