is this solder still good???
Old Jan 5, 2007 | 08:40 PM
TheTealHatch's Avatar
Default is this solder still good???
well lately my car hasnt been starting and i was wondering if this solder part from my main relay has went out?? im not even sure, so if you guys could help me out.
Old Jan 5, 2007 | 08:42 PM
EG93si's Avatar
nope, its fine
Old Jan 5, 2007 | 08:45 PM
Default Re: is this solder still good??? (SLOW_TEAL_HATCH)
edit picture. i changed the picture. the middle one. its a little crack.
Old Jan 5, 2007 | 08:48 PM
EG93si's Avatar
as long as it dosn't noticeably move its fine, if your worried you can heat up the iron melt a little bead or solder to it then tap the top of the prong and it will roll down and recoat it. i do this **** all day long at work. but it really should be fine
Old Jan 5, 2007 | 08:51 PM
Default Re: is this solder still good??? (EG93si)
well i read on this site and my join looks like this
http://www.marklamond.co.uk/te...y.htm
Old Jan 5, 2007 | 08:52 PM
may this be the reason my car wont start up?
Old Jan 5, 2007 | 09:06 PM
EG93si's Avatar
i work for daktronics and i solder probly about an hour a day, ive never even heard of solder doing that, but if you really want to fix it like in that thread, i suggst desoldering them and replacing it all with new solder. as long as theres contact though, i dont know why it wouldn't want to work
Old Jan 5, 2007 | 09:24 PM
Default Re: (EG93si)
well maybe i should give it a shot and try it out. but thanks for the help.
Old Jan 5, 2007 | 10:57 PM
alacard's Avatar
did you ever drop the main relay or anything like that? if so, wiggle stuff around and eventually it should get the car to start atleast once, so you can move it to your garage etc. then order a new one from honda for like 40 bucks. if this isnt the problem, we will need more info to help you out
edit: my main relay was damaged and causing my car not to be able to start without any visible marks.
Harryflores's Avatar
it should be fine !
Old Jan 5, 2007 | 11:32 PM
Default Re: is this solder still good??? (Harryflores)
well it started up a few times today and it completely died and thats it. ive cranked it and nothing. and there is a spark cause i checked that today. so what now
Old Jan 6, 2007 | 01:04 AM
Default Re: (Zach_06)
yup
Old Jan 6, 2007 | 08:22 AM
JSPECSIR's Avatar
Default Re: (SLOW_TEAL_HATCH)
looks like a cold solder ring to me. i would deff. resolder it. if its not it wont cost **** to resolder it anyway. and yes a ring like that would make a diff. the piece does not have to wiggle around, the contact at that ring will open and close with temp.l
Old Jan 6, 2007 | 12:24 PM
Default Re: (JSPECSIR)
thanks. ima get it resolder by my friends dad. thanks guys
black94lude
Jul 30, 2009 02:11 PM
KickStart2323
Jun 8, 2009 12:19 PM
si_hatch
Oct 21, 2004 10:43 AM
