Oil Sandwich plate for a DOHC ZC?
I'm prepping my DOHC ZC to be boosted and I am under the impression that I will need an oil sandwich plate for an oil feed. If so, does anyone have any recommendations for which one to run? Also, do I stack my stock oil-to-water intercooler on the sandwich plate, or does this cooler get ditched when I set up my turbo oil feed? Thanks.
There are other ways to get an oil pressure feed besides a sandwich plate adapter. Teeing off the pressure sensor is the easiest. I'd be willing to bet you could get a feed off the head somewhere too. I wouldn't run the plate over the stock oil cooler. I would keep that oil cooler, not ditch it for the adapter either. Just get your oil feed from the pressure sensor, it's alot cheaper than a plate.
People are scared to break the tees off in the block but that is all I have ever used with no probs at all. Stealthmode kit is cheap and good quality!
x2 for the tee. I always use that and it's super easy. You can get the parts at your local hardware store provided you get a BSpT to NPT adaptor for the block. http://www.mcmaster.com/
bchap
Oct 7, 2009 06:55 PM
