i need your advice
Old Jan 5, 2007 | 05:58 PM
DC4 Rasta's Avatar
Default i need your advice
Im honing out my ls block to put in some je 9:2:1 pistons. i read that with a factory hone the piston to wall clearance is 0.0001- 0.0002, also you can bore your cylinder 1 mm over with no problems. so i am trying to get back the factory piston to wall clearance. the pistons are .25 oversized so im guessing the hone should be any where from .2501-.2502. if this is right what type of piston rings should i use. piston rings with the standard bore or rings with with .25 oversized.
i would like your to know what you think. thanks
Old Jan 5, 2007 | 06:43 PM
doood's Avatar
been there done that
Default Re: i need your advice (DC4 Rasta)
their should be a spec sheet that came with those pistons with recommended install clearances. the factory clearances are no good with those pistons because they're forged and will expand with heat.
Old Jan 5, 2007 | 06:44 PM
-Darren-'s Avatar
if you don't get help here, try the allmotor or force induction section.
deanobob123
Apr 9, 2018 12:16 PM
JDM-EJ698
Apr 23, 2009 06:29 PM
5_Lug_B
Aug 5, 2007 09:26 PM
siis2fast
Jun 7, 2005 03:52 AM
ek
Jun 10, 2002 08:52 AM
