sand bending
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RocCityRoller;1052516 »</TD></TR><TR><TD CLASS="quote">Not sure if this is the right spot for this, move it if need be. Stumbled across this on the forum I'm on in Michigan and thought it was an interesting/helpful read if you wanted to try something like this.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blind-Fashion »</TD></TR><TR><TD CLASS="quote">Isn't that kind of how they make mandrel bends? fill them with sand and bend them? but without the heat? </TD></TR></TABLE>
HAHA, no
They insert a "mandrel" into the tube so that when the tube is bent it maintains it's structure.
Like here:
HAHA, no
Like here:
Definitely have heard of this technique, but that's a pretty good article. I have never seen actual pipe bent this way. It looks to be good quality. Might be worth trying.
REMEMBER TO USE DRYED SAND!!!! otherwise the pipe WILL explode.
I have tried to bend some 2.5" exh piping this way, but it didnt really work out. It defenately isent as easy as it looks.
i dont see too much "easy" in that article.. looks like it would take a pretty good amount of time and work to get a bend you can buy for not tooo much more than straight.
Seems like a really good idea. Pack the sand in tight, weld on end caps, then bend that ish in your crappy die pipe bender. Should come out better than the die bender alone, right?
is it possible to just torch the moisture out of the sand, or does this need to be done in an oven?
I might try this out, it'd be nice to know how to do this. Just doing some 2" pipe for my wagon so I'm not running an open cat
