all done but stuck
hey guys all done with the swap but I stuck now. It's a B16a with a 99 B16a2 intake manifold. I'm stuck with this outlet. Don't no what to do with it, If I leave it open the motor idles high, when I plug it the motor run normal only when it's warmed up. When I plug it and then start the car the motor want's to die. Anyone know what to do with this THING...........thanks
[Modified by si foo, 4:47 PM 5/14/2002]
Do you know what it is suppost to go to?
Could you posssiblty try using a t-fiting into a diff vaccum line and see what works. try all sorts of diff lines and see if it runs better.
[Modified by ED6, 12:14 PM 5/14/2002]
I think the reason its killing when its plugged on a cold start is due to another proble, possibly with the IAC, I would say plug it, because when its open its nothing more than a large vacuum leak and plugging a vacuum leak can't make your car kill on a cold start/idle. When I fist did my swap, I had problems with idleing. make sure the wires for the IAC aren't crossed, I find that if you lose the coolant lines running through it it causes some idle issues. could be a few things, but I doubt plugging that vacuum port is your problem
Hope this helps
Chris
Hope this helps
Chris
ShagPower
15
Sep 2, 2006 08:28 AM
