FS: HKS EVC EZ Electronic Boost controller
For sale:
-HKS EVC EZ Boost Controller
Condition:
-Perfect working condition. Took it off of a working car. We decided to run off of a spring instead.
Description:
-Includes the Main controller unit, solenoid, & harness
-This is the easiest EBC to work with. No messy wiring job, just a simple power and ground wire to power the unit. The solenoid hooks up to the top and side port of your wastegate and you control boost via the controller box.
HKS Description:
-Quoted from HKS "The EVC EZ is the most simple version of HKS' electronic
boost controllers, but still utilizes the same proven stepping motor
as the EVC IV and EVC PRO. With the same "state of the art" closed
loop stepping motor, you are insured the same most accurate and stable
boost levels possible. Boost pressure will rise faster and earlier in
each gear and be maintained without fear of overboosting. The EVC EZ
uses a retractable volume **** to adjust boost to the desired levels
and a power switch to return the boost levels back to baseline/stock.
Boost pressure can be adjusted up to 2.5bar (36.25psi) via the
illuminated **** on the head unit. Just like the EVC IV and EVC Pro,
the EVC EZ can be used with internal and external wastegate setups on
both parallel and sequential twin turbo and single turbo applications.
The EVC EZ offers the accuracy and consistency given by our electronic
boost controllers, but with the simplicity of a manual boost
controller. An external boost meter will be needed to calibrate the
adjustment of boost pressure. EVC EZ features Simple Easy to use
design Adjustable up to 2.5bar (36.25psi) Internal and External
wastegate applicable Precision "closed-loop" boost regulating stepping
motor Dimensions: EVC Headunit- 112mm (W) X 25mm (H) x 84mm (D) EVC
Stepping Motor- 58mm (W) X 50mm (H) X 48mm (D) " end quote.
Price:
-I am looking to get 200 shipped for the EBC, or best offer. Please send me a PM if you are interested.
Pictures:
Shipping
-I will ship this item as soon as I receive payment. I will PM the buyer with the tracking details as soon as it goes out for shipment.
References:
-I have sold numerous things on HT, please see my SIG for vouches there. My eBay feedbacks can be seen here:http://feedback.ebay.com/ws/eB...E:UFS
Other references are available upon request (other forums).
Condition:
Description:
HKS Description:
Price:
Pictures:
Shipping
References:
LeGeND4LiFe
May 1, 2006 04:07 PM
spork
Jan 16, 2003 01:39 PM
