MFactory Spherical-Bearing Suspension Setup - AS USED ON OUR H1 HONDA CHALLENGE CIVIC
Hello Honda-Tech,
we are proud to offer the full range of MFactory Spherical-Bearing suspension components, as used on our H1 Honda Challenge EG Civic, at special HT Online Prices
Rear Toe Adjusters/Compensators
Fine tune your handling performance with the MFactory Rear Toe Adjusters. By allowing you to adjust the rear toe settings to suit you race application, you can shave seconds off your lap times and gain a competitive advantage over the competition. Through the use of next-generation Japanese spherical bearing technology, our toe adjusters offer near-zero deflection and 100% multi-axis movement. We have virtually eliminated bush wear and binding commonly seen with competing products that utilize inferior Polyurethane bushings and offer true "maintenance-free" usage.
- High-Tensile Forged Carbon Steel construction for increased strength
- Teflon-lined 3-Piece Chromoly Race Bearings for noise-free maximum performance
- Rubber Dust Boots to ensure the utmost reliability
Fitments: Civic 88-00/Integra 94-00
MSRP: $139.95 + Shipping
HT Special: <FONT COLOR="red">$129.95 Shipped!!</FONT>
Rear Camber Kit/Upper Control Arms
Gain an edge over the competition with the MFactory Rear Camber Kit, allowing for easy and accurate camber adjustments to be made at the rear wheels. Through the use of next-generation Japanese spherical bearing technology, our camber kits offer near-zero deflection and 100% multi-axis movement. We have virtually eliminated bush wear and binding commonly seen with competing products that utilize inferior Polyurethane bushings and offer true "maintenance-free" usage.
Fitments: Civic 88-00/Integra 94-00, Civic 01-05/Integra 01-06
MSRP: $139.95 / $149.95 + Shipping
HT Special: <FONT COLOR="red">$129.95 / $139.95 Shipped!!</FONT>
Rear Lower Tie Bar
Constructed entirely from hot-pressed carbon fibre + steel dies via a light-duty production process, the MFactory Rear Lower Tie Bar not only looks great, but helps to increase chassis rigidity essential for cornering stability.
- Extremely high-rigidity textures of the tie bar resists pressure of up to 350kg, increasing strength & performance
- Can be installed with factory suspension components
Fitments: Civic 92-95/96-00
MSRP: $99.95 + Shipping
HT Special: <FONT COLOR="red">$89.95 Shipped!!</FONT>
Rear Lower Control Arms
Increase performance and style with the MFactory Rear LCA's, designed specifically for the rigors of competition use. Through the use of next-generation Japanese spherical bearing technology, our LCA's offer near-zero deflection and 100% multi-axis movement. We have virtually eliminated bush wear and binding commonly seen with competing products that utilize inferior Polyurethane bushings and offer true "maintenance-free" usage.
- Near-Zero deflection and 100% multi-axis movement
- Forged Aluminum construction for increased strength and weight savings
- Teflon-lined Chromoly Race Bearings with Anti-Dust technology for maximum performance
- Modular design allowing easy replacement of bearings
- Within OEM spec for direct replacement of factory LCA's
MSRP: $249.95 + Shipping
HT Special: <FONT COLOR="red">FREE SHIPPING</FONT>
COMING SOON:
- Front Spherical-Bearing Camber Kits/Upper Control Arms for EG/EK/DC2
- Front LCA Replacement Spherical Bearings for EG/EK/DC2
HT SPECIAL: Order over $100 and get a FREE <FONT COLOR="red">$10 Gift Voucher</FONT>
If you have any questions, please feel free to send me a PM
To order at HT Pricing (Online Ordering Only), please click here: www.teamMFactory.com
Modified by MFactory at 2:50 AM 9/3/2008
Rear Lower Tie Bar
COMING SOON:
