EF CRX Civic H22 swap parts (Hasport, Rywire, Fiber Images, Griffin radiator, MSD, ST, linkage)
Old Jan 5, 2007 | 09:29 AM
2lude4u's Avatar
Default EF CRX Civic H22 swap parts (Hasport, Rywire, Fiber Images, Griffin radiator, MSD, ST, linkage)
These are the remaining part from my H23A swapped EF hatch part-out
Transmission:
Fidanza 8lb flywheel (it's used)- $60
Resistor box- $20
Starter- $20
H series Alternator- $25
D series Alternator- $20
Crank Pulley Tool- $35
Complete EF AC system (except the AC harness)- $75
SOLD:
Fiber Images carbon fiber hood w/ hood pins
Volk/Rays GRN's
MSD SCI ignition with Blaster SS coil
ST Front Sway bar
H22 OBD1 external coil dizzy w/ plug wires
Griffin Radiator EG half radiator
Custom 2 1/2” resonated exhaust for EF's
Explicit Speed front strut tower bar
Momo hub
Hasport EFH1 motor mounts (swap an H/F series into an EF or CRX)
Rywire Harness H22/EF engine Harness & obd0-obd1 ECU harness
Progress rear sway bar
Forbidden Short Shifter & Prelude shift linkage
Volk Group C 15” with 215/45 Falken Azenis RT615
Rays lug nuts
Modified by 2lude4u at 12:35 PM 2/23/2007
Old Jan 5, 2007 | 01:46 PM
2lude4u's Avatar
Default Re: EF CRX Civic H22 swap parts (2lude4u)
Hasport
Old Jan 6, 2007 | 06:40 AM
2lude4u's Avatar
ARP
Old Jan 6, 2007 | 10:21 AM
2lude4u's Avatar
custom
Old Jan 6, 2007 | 09:16 PM
h22addiction's Avatar
Will the rywire ef harness work for h22 swap into 88 crx si? Thanks
Old Jan 7, 2007 | 08:31 AM
2lude4u's Avatar
Default Re: EF CRX Civic H22 swap parts (h22addiction)
I don't think it will. I believe SI's & DX's have different ECU harnesses so it won't match up. If they do have the same ECU harnesses, then it will work.
Old Jan 8, 2007 | 04:13 PM
2lude4u's Avatar
TTT
Old Jan 8, 2007 | 05:47 PM
Turbocivic94's Avatar
Does radiator come with fan?
Is inlet and outlet for b series?
Old Jan 8, 2007 | 06:53 PM
2lude4u's Avatar
Default Re: EF CRX Civic H22 swap parts (Turbocivic94)
pm'd
Old Jan 9, 2007 | 06:26 PM
Carolina Fried Rice's Avatar
I may need some of these parts soon... will get back to you.
bump for you.
Old Jan 10, 2007 | 01:32 PM
2lude4u's Avatar
Default Re: EF CRX Civic H22 swap parts (Carolina Fried Rice)
hit me up when you know
Old Jan 10, 2007 | 04:50 PM
2lude4u's Avatar
bump
Old Jan 11, 2007 | 03:03 PM
2lude4u's Avatar
Griffin
Old Jan 14, 2007 | 08:28 AM
2lude4u's Avatar
Forbidden
Old Jan 14, 2007 | 03:21 PM
90Burgandykilla's Avatar
I am definately going to need some parts. Just wondering if anything is already gone?
TJ
Old Jan 14, 2007 | 03:24 PM
Where are you located at?
TJ
Old Jan 14, 2007 | 04:40 PM
2lude4u's Avatar
Default Re: EF CRX Civic H22 swap parts (90Burgandykilla)
I update my thread regularly, & started this new thread because the old one was so full of stuff I had sold. Everything listed above is still available.
Located in UTAH
Old Jan 14, 2007 | 10:11 PM
Vinceg99's Avatar
PMed
Old Jan 14, 2007 | 11:11 PM
beaneg6's Avatar
Default Re: EF CRX Civic H22 swap parts (Vinceg99)
is that an prelude intermediate shaft? if so ill take it....
Old Jan 15, 2007 | 04:54 AM
2lude4u's Avatar
Default Re: EF CRX Civic H22 swap parts (beaneg6)
If it's not listed, I don't have it anymore, like the H22 intermediate shaft, sorry.
Old Jan 15, 2007 | 09:56 AM
beaneg6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2lude4u &raquo;</TD></TR><TR><TD CLASS="quote">If it's not listed, I don't have it anymore, like the H22 intermediate shaft, sorry.</TD></TR></TABLE>
no problem thanks
Old Jan 15, 2007 | 01:56 PM
2lude4u's Avatar
np
Old Jan 15, 2007 | 05:10 PM
2lude4u's Avatar
Fidanza
Old Jan 16, 2007 | 03:41 PM
2lude4u's Avatar
E-speed
Old Jan 17, 2007 | 03:09 PM
2lude4u's Avatar
Suspension Techniques
