EDM suspension
Old Jan 5, 2007 | 08:09 AM
nexgen91's Avatar
Default need suspension help
I bought a 90 EDM CRX 1.6i-16 (ZC) it has factory roll bars and one piece coilovers (not sure of the make) on it, I am thinking about transfering this and the rear disk brakes to my USDM 91 Civic hatch (DX w/ B16 swap), and wondering if this would be easy and worth my time. Also will the main exhaust pipe from a CRX fit on a civic HB? Thanks
Modified by nexgen91 at 12:14 AM 1/7/2007
Old Jan 6, 2007 | 03:13 PM
nexgen91's Avatar
Default Re: need suspension help(nexgen91)
Bump
Old Jan 6, 2007 | 03:43 PM
civicandy's Avatar
Default Re: need suspension help(nexgen91) (nexgen91)
Here's my take on this.
1. Why not keep the EDM car as is? You could find Si sway bars for the USDM hatch. I have a US Si front sway bar and DA rear. Cheap at junk yards.
2. Suspensions are the same between crx and hatch, except I'm not sure if the sway bars swap over. Check your lower control arms in the rear to make sure they have the bolt hole for the sway bar link.
3. Disk brakes would work fine. Not sure if the parking brake cables work. I believe they do. I used DA rear disks and DA break cables.
Hope this helps some
Old Jan 7, 2007 | 02:07 AM
nexgen91's Avatar
Default Re: need suspension help(nexgen91) (civicandy)
Im in Europe, I dont even know if junk yards exisit here, or I would definatly do that. Im going to be taking the coilovers off anyways, so I figure why not just take the other stuff also. Im taking my hatch back to the states with me when I leave Germany. I will be selling the CRX so I wont even have it. I would have to change the LCAs for the sway bars to work, but thats no big deal. Thanks for you help.
Old Jan 7, 2007 | 03:39 AM
lonestarEE9's Avatar
From: Magdeburg, represent Deutschland..y0, Germany
Hi,
the suspension fits on your HB.the rollbars,too
but the cables from the handbrake are too short.
1991ED6
Sep 29, 2012 01:53 PM
hondacivic4g
Jan 6, 2005 09:56 PM
SIsohcvtec
12
Sep 22, 2004 01:46 PM
tysf
Aug 19, 2003 08:41 PM
yolooky
10
Dec 31, 2001 01:26 PM
