Clutch Problem!!
Old Jan 5, 2007 | 07:34 AM
89bluehatch's Avatar
Default Clutch Problem!!
ok first off i have a 89 civic dx hatchback, all completely stock, i bought it about a year ago,
well i cant figure out why the clutch is so stiff and i have to push on the clutch pedal somewhat hard, my main issue is i keep going through pedal brackets because i keep breaking them, i've checked the clutch cable and it moves freely and is not bound up in any way, and the clutch pedal moves freely and everything is brand new, also i recently had a shop replace the clutch about 4 months ago because the clutch was starting to slip, also ive had this problem since the day i got the car
Old Jan 5, 2007 | 02:17 PM
roterx7's Avatar
Default Re: Clutch Problem!! (89bluehatch)
if u had the shop do it for you bring it back and ask them whats going on here
Old Jan 5, 2007 | 02:54 PM
Boosted Chemist's Avatar
Default Re: Clutch Problem!! (roterx7)
not enough grease on the throwout bearing.
Old Jan 6, 2007 | 10:58 AM
Default Re: Clutch Problem!! (Boosted Chemist)
so u think just grease the throwout bearing and it should be fine?
Old Jan 6, 2007 | 03:20 PM
LankorDie's Avatar
Loved
Community Favorite
Check out my thread, I'm having the same type of problem. Other then the clutch slipping, I havent ran into that yet.
https://honda-tech.com/zerothread/1770756
Old Jan 7, 2007 | 10:07 AM
well u think grease could be the only problem? because i had this problem before and after the clutch was replaced
0_civic_4
Aug 5, 2010 05:07 PM
renes
Nov 21, 2005 11:25 AM
tweekerz
Jul 11, 2005 01:28 PM
JdmFront619
Oct 28, 2003 12:25 PM
