BRAKES WENT OUT
Old Jan 5, 2007 | 12:51 AM
i HEART my Honda's Avatar
Default BRAKES WENT OUT
I was driving my 99 DX today (w/ jdm h22 swap) and all of a sudden the brakes stoped working normally, i litterally had the push down the brake pedal as hard as i could to stop the car. Any ideas?
Old Jan 5, 2007 | 01:10 AM
Jimmy's Avatar
Global Moderator
Default Re: BRAKES WENT OUT (i HEART my Honda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by i HEART my Honda &raquo;</TD></TR><TR><TD CLASS="quote">I was driving my 99 DX today (w/ jdm h22 swap) and all of a sudden the brakes stoped working normally, i litterally had the push down the brake pedal as hard as i could to stop the car. Any ideas? </TD></TR></TABLE>
Failing brake booster, master cylinder, pads worn.. Numerous things.. No one's gonna be able to help without any DETAIL.
Old Jan 5, 2007 | 01:20 AM
Default Re: BRAKES WENT OUT (Jimmy)
hmmm im not sure how to provide details. I was flooring it in first gear, slowed down and felt that my brakes were not responding. I added fluid and pumped the brakes to see and feel any change, but nothing changed. I feel a lot of resistance, as if the brakes dont pedal doesnt want to move.
Old Jan 5, 2007 | 01:23 AM
Jimmy's Avatar
Global Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by i HEART my Honda &raquo;</TD></TR><TR><TD CLASS="quote">hmmm im not sure how to provide details. I was flooring it in first gear, slowed down and felt that my brakes were not responding. I added fluid and pumped the brakes to see and feel any change, but nothing changed. I feel a lot of resistance, as if the brakes dont pedal doesnt want to move.</TD></TR></TABLE>
There's probally a **** ton of air in there now.. Did your squeelers wear down? Hear any grinding noises before? See any visual leaks? check your front and rear brake lines.
Old Jan 5, 2007 | 01:26 AM
Frozen E's Avatar
H-T White Ops
My money's on his brake booster going bad.
Old Jan 5, 2007 | 06:07 AM
kaiba's Avatar
Default Re: (IslandSi)
Low in fuild = low in brake pad.
I say time for a brake upgrade. Brembo blanks with hawk hps and some good brake fuild.
Old Jan 5, 2007 | 06:24 AM
instructor74's Avatar
Default Re: (kaiba)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IslandSi &raquo;</TD></TR><TR><TD CLASS="quote">My money's on his brake booster going bad.</TD></TR></TABLE>
That's where my money is . The booster is just that .......it reduces the amount of work you have to do to push the brake pedal. when they stop working your brake pedal gets hard to push.
Old Jan 5, 2007 | 06:48 AM
Default Re: (instructor74)
ok first things first, brake booster
Modified by i HEART my Honda at 8:53 AM 1/5/2007
Old Jan 5, 2007 | 06:52 AM
Mike_C's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jimmy &raquo;</TD></TR><TR><TD CLASS="quote">
There's probally a **** ton of air in there now.. Did your squeelers wear down? Hear any grinding noises before? See any visual leaks? check your front and rear brake lines.</TD></TR></TABLE>
air in the lines doesn't result in the pedal being hard to press. it results in the opposite...
1. grinding feeling? pads are gone.
2. soft pedal? air in line, leaking caliper or line.
3. pushing hard, but not much braking? booster bad.
4. push and hold, pedal slowly sinks? master cylinder bad.
Old Jan 5, 2007 | 07:52 AM
Default Re: BRAKES WENT OUT (Mike C)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mike C &raquo;</TD></TR><TR><TD CLASS="quote">
4. push and hold, pedal slowly sinks? master cylinder bad.</TD></TR></TABLE>
Its #3 for sure then... Thanks for the tips guys. But does this mean i have to buy a new booster? If so, where can i pick it up for a decent price? Autozone, pepboys, etc?
Old Jan 5, 2007 | 09:16 AM
Default Re: BRAKES WENT OUT (JJSpecTuning)
I dont have rear conversion. But ill look for a brake booster from a GSR
Old Jan 5, 2007 | 09:30 AM
Luserkid's Avatar
The GSR brake booster wont work unless if you have an integra master cylinder. I had someone bring me there car with this problem and it turned out to be the check valve was reversed. Did you ever have good brake pedal or was it always like this?
Old Jan 5, 2007 | 09:35 AM
kaiba's Avatar
Default Re: BRAKES WENT OUT (Luserkid)
WOW. I was gonna say use the si 99-00/ex 96-00 but they have the same sizer booster.
Old Jan 5, 2007 | 09:59 AM
Default Re: BRAKES WENT OUT (kaiba)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">The GSR brake booster wont work unless if you have an integra master cylinder. I had someone bring me there car with this problem and it turned out to be the check valve was reversed. Did you ever have good brake pedal or was it always like this? </TD></TR></TABLE>
Yes it was actually fine while i was driving home and then i floored it for about 1/8 mile and then the brakes got super super stiff and the car wouldnt stop unless i pushed down the brake pedal as hard as i could.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kaiba &raquo;</TD></TR><TR><TD CLASS="quote"> WOW. I was gonna say use the si 99-00/ex 96-00 but they have the same sizer booster. </TD></TR></TABLE>
I dont get this, are you saying i CAN use a brake booster from a 99-00 si?
and just wanted to say thanks again for all your guys help.
Old Jan 5, 2007 | 10:03 AM
kaiba's Avatar
I dont get this, are you saying i CAN use a brake booster from a 99-00 si? </TD></TR></TABLE>
Yes, If my research is correct. They seem to have the same part#.
Old Jan 5, 2007 | 12:02 PM
thanks guys!
Old Jan 5, 2007 | 12:05 PM
EL Vap133's Avatar
Sure but the 99-00 SI brake booster is the same size as the DX booster.
Old Jan 6, 2007 | 01:32 AM
Default Re: BRAKES WENT OUT (EL Vap133)
i found the problem, going to fix it in the morning.
Old Jan 6, 2007 | 02:55 AM
Mike_C's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by i HEART my Honda &raquo;</TD></TR><TR><TD CLASS="quote">i found the problem, going to fix it in the morning. </TD></TR></TABLE>
care to share?
Old Jan 6, 2007 | 02:56 AM
poison's Avatar
Glad you found the problem. What was it?
94 IntegraLS
21
Jun 11, 2012 08:41 PM
fatpride111
10
Nov 5, 2007 02:16 PM
99SlammedCivic
21
Apr 12, 2004 07:47 AM
Mike_C
Apr 1, 2004 11:18 AM
