pillow ball mount question
Old May 14, 2002 | 06:19 AM
617arg's Avatar
Default pillow ball mount question
hey there......quick question. are pillow ball mounts universal?
ie: will JIC pillow ball mounts be compatable with a Zeal setup?
thanks
argiris
Old May 14, 2002 | 09:37 AM
617arg's Avatar
Default Re: pillow ball mount question (argiris)
ttt......sorry i know someone has to know this
thanks
argiris
Old May 14, 2002 | 09:46 AM
Money Hou$e's Avatar
Sorry this may sound stupid, but what exactly is a pillow ball mount and what does it do? I've heard you really don't need to use them, any truth to this?
Old May 14, 2002 | 10:04 AM
Asahi's Avatar
Default Re: pillow ball mount question (mltdown)
PBM's replace the assembly cap on a stock setup. They are not required.
Old May 14, 2002 | 12:46 PM
617arg's Avatar
what asahi said.....they are not required, but the adjustable ones let you change your camber quickly at the track.
i'm thinking that they are universal.....but before i throw down the cash i'd like to know for sure.
thanks
argiris
Old May 14, 2002 | 12:47 PM
IntegraT's Avatar
change camber???
Old May 14, 2002 | 12:51 PM
Warren's Avatar
Wrong-Way Wang
There is no changing of camber to be had here
Warren
Old May 14, 2002 | 12:54 PM
Asahi's Avatar
Default Re: pillow ball mount question (Warren)
cambet is not adjustable without special kits and not something you would want to do off an alignment rack. using a PBM is sort of the same reasoning as changing to Poly bushings. Just more stability. Not really any adjustability.
Old May 14, 2002 | 01:01 PM
Default Re: pillow ball mount question (Asahi)
Cool, I learn something new everyday.
Old May 14, 2002 | 01:09 PM
617arg's Avatar
i guess i learned something new too
so whats the difference with aluminum perches and pillow mounts?
the reason i thought you can adjust the camber is because that's what i read here:
http://www.digitalracer.com/catalog/...85#JIC%20Magic
maybe i shouldn't beleive everything i read!
thanks for clearing that up
argiris
Old May 14, 2002 | 01:42 PM
EagleR's Avatar
I beleive w/ some you can dial alot more cater i. Just my .02 cents and I've been wrong before. Ps. thats not something to change off a rack unless you are a race engineer w/ proper equiptment.
Old May 14, 2002 | 01:50 PM
AssPenny's Avatar
Default Re: pillow ball mount question (EagleR)
You can adjust the camber on pillow mounts if the car uses macphersian (sp? i know thats way off) struts like the RSX.
Craig - Who really should go back to school and take english 101
Old May 14, 2002 | 02:02 PM
Warren's Avatar
Wrong-Way Wang
You can't adjust caster either. The shocks (not struts) do not affect suspension geometry on this car.
You can try tilting the shocks, and watching the piston rod bend on the first hard hit. That would be cool. Get it on video
Warren
Old May 14, 2002 | 02:05 PM
sgT's Avatar
sgT
lol
yes, only macphereson strut setups can change susp dynamics with an adjustable
upper shock mount.
Old May 14, 2002 | 02:09 PM
AssPenny's Avatar
Default Re: pillow ball mount question (sgT)
lol
I was sorta close... thanks for the help
Old May 14, 2002 | 02:10 PM
sgT's Avatar
sgT
Default Re: pillow ball mount question (AssPenny)
maybe its macpherson
something like that
Old May 14, 2002 | 03:01 PM
MK Ultra's Avatar
"McPherson."
Scottish for "piece of crap."
Old May 14, 2002 | 03:04 PM
sgT's Avatar
sgT
Default Re: pillow ball mount question (MK Ultra)
I just checked. its Macpherson
Old May 14, 2002 | 03:12 PM
EagleR's Avatar
told ya I've been known to be wrong. to me!
Old May 15, 2002 | 03:08 AM
tecnic1's Avatar
Macpherson=less expensive then multilink
HondaheadBigNick
Suspension & Brakes
Nov 13, 2009 07:59 PM
trrbl1bmx
21
Jun 17, 2008 06:14 AM
SiR-G DC
Suspension & Brakes
11
Nov 22, 2007 12:48 PM
JustOneMore
May 4, 2004 06:00 PM
PressurizedSi
Sep 18, 2002 01:18 PM
