Shifter wobbly... help? why?
Old Jan 4, 2007 | 08:03 PM
SpOoLiNg CiViC's Avatar
Default Shifter wobbly... help? why?
ok... i can put my shifter into 1st and 2nd and 3.. all the gears... once it's in gear i can wobble it around and it's like if it were to be in 1st i could put it where it LOOKS like it's in 3rd gear but still in first... why is it so loose? any way to tighten it up or to get some sort of bushings? i just ordered short throw shifter so when i go to install it... anything i can do to keep this from being so wobbly as well???
thanks fella's
Old Jan 4, 2007 | 08:09 PM
Eran's Avatar
HT White Ops
Shifter bushings are the most likely culprit.
Old Jan 4, 2007 | 08:21 PM
Default Re: (Eran)
i looked on ebay and stuff i cant find any shifter bushings... where should i look... that are a good pirce...
Old Jan 4, 2007 | 08:23 PM
Eran's Avatar
HT White Ops
Default Re: (SpOoLiNg CiViC)
are you high?
http://search.ebay.com/search/...shing
there ... 20 results in 2 seconds.
Old Jan 4, 2007 | 08:29 PM
Fatchance187's Avatar
Default Re: (Eran)
Energy Suspension is the most common brand I've seen people get, and they get a from me as well.
Old Jan 4, 2007 | 08:31 PM
Eran's Avatar
HT White Ops
Default Re: (Fatchance187)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fatchance187 &raquo;</TD></TR><TR><TD CLASS="quote">Energy Suspension is the most common brand I've seen people get, and they get a from me as well.</TD></TR></TABLE>
I have them, the red kind (non-lubricating). They work just jim-dandy.
Old Jan 4, 2007 | 08:37 PM
F20Cteg's Avatar
Default Re: Shifter wobbly... help? why? (SpOoLiNg CiViC)
Sounds like you have a stock shifter. Bushings will not cause that much play.
The shift mechanism inside tranny uses a torque spring to return it to center from the left-right motions.
This spring will wear out and become weak. It mostly happens on the center to 1-2 movement because that is the most used.
Put on you new shifter and see if still happens. If is does, just the spring inside.
Old Jan 4, 2007 | 10:05 PM
Frozen E's Avatar
H-T White Ops
Two words
"Bitch Pin"
Search for it on here. Causes everything you described.
Old Jan 4, 2007 | 10:12 PM
SiYouLater's Avatar
Before buying anything check to see if the bolt holding the shifter is lose. Go under the car behind the cat and you can see the bottom of the shifter. There is bolt that connects the shifter to the linkage. If that comes lose then the shifter will have play.
Old Jan 4, 2007 | 10:30 PM
VRD^don's Avatar
Default Re: (IslandSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IslandSi &raquo;</TD></TR><TR><TD CLASS="quote">Two words
"Bitch Pin"
Search for it on here. Causes everything you described.</TD></TR></TABLE>
that could be the problem too...my buddies hatch was like this and it was because of the bitch pin...
Old Jan 4, 2007 | 11:03 PM
Frozen E's Avatar
H-T White Ops
Default Re: (k_motor)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by k_motor &raquo;</TD></TR><TR><TD CLASS="quote">
that could be the problem too...my buddies hatch was like this and it was because of the bitch pin... </TD></TR></TABLE>
$.79 fix from Home Depot.
Old Jan 5, 2007 | 12:30 AM
dohcteg's Avatar
I think it is the bitch pin also. I have the same darn problem... right now i'm changing the shifter bushing by energy suspension to see if it helps... If it doesnt solve it then ill have to fix the bitch pin.
(sorrie didn't mean to just took over ur thread) since we're on the topic... just wondering when u guys install the shifter bushing.. do you have to grease it up? If yes then what kind of grease should i use and do i grease both bushings? Thanks
Old Jan 5, 2007 | 12:50 AM
Jimmy's Avatar
Global Moderator
Default Re: (dohcteg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohcteg &raquo;</TD></TR><TR><TD CLASS="quote">I think it is the bitch pin also. I have the same darn problem... right now i'm changing the shifter bushing by energy suspension to see if it helps... If it doesnt solve it then ill have to fix the bitch pin.
(sorrie didn't mean to just took over ur thread) since we're on the topic... just wondering when u guys install the shifter bushing.. do you have to grease it up? If yes then what kind of grease should i use and do i grease both bushings? Thanks </TD></TR></TABLE>
No grease needed..
Old Jan 5, 2007 | 09:58 AM
pli's Avatar
pli
Default Re: (Jimmy)
theres the energy suspensions which work really well. i have those on mines. stiff as hell, but i love it!!
you can try the password:jdm's bushing and give us a review on it or something =P http://passwordjdm.com/product...D=365
jb0705
Jul 10, 2009 12:39 PM
00civicsiboy
Mar 22, 2009 06:41 PM
civic_coupe_585
13
Nov 9, 2007 02:03 PM
jokerstone
Aug 6, 2007 04:21 PM
MrSmith
Aug 7, 2001 07:39 AM
