Blown Head Gasket??
Old Jan 4, 2007 | 04:18 PM
4theluvofhonda's Avatar
Default Blown Head Gasket??
I was told by Honda Dealership that I have a blown head gasket, but it has been 3 months still running with still no symptoms of a blown head gasket. It is running through coolant at least once a week, but no leaks. I have replaced thermostat, radiator cap, and radiator.
Old Jan 4, 2007 | 04:23 PM
Default Re: Blown Head Gasket?? (JJSpecTuning)
how do you do the leakdown test?
Old Jan 4, 2007 | 04:50 PM
Si_chRis's Avatar
Default Re: Blown Head Gasket?? (4theluvofhonda)
You can tell if it's blown if your oil is like milky brown, overheating of engine, and if there is white residue on your underside of oil cap...at least that is what I heard.
Old Jan 4, 2007 | 04:55 PM
Default Re: Blown Head Gasket?? (EM1_ChRiS)
It hasn't had milky oil nor the typical white smoke coming from the exhaust.
Old Jan 4, 2007 | 05:03 PM
Brick Top's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4theluvofhonda &raquo;</TD></TR><TR><TD CLASS="quote">I was told by Honda Dealership that I have a blown head gasket</TD></TR></TABLE>
i would go with what they say. and if its eating coolant, its a typical sign. and will only get worse.
Old Jan 4, 2007 | 05:06 PM
Turbo_y8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EM1_ChRiS &raquo;</TD></TR><TR><TD CLASS="quote">You can tell if it's blown if your oil is like milky brown, overheating of engine, and if there is white residue on your underside of oil cap...at least that is what I heard.</TD></TR></TABLE>
our hondas dont commonly show the common blown head gasket sings
Old Jan 4, 2007 | 05:09 PM
Brick Top's Avatar
Default Re: Blown Head Gasket?? (Turbo_y8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo_y8 &raquo;</TD></TR><TR><TD CLASS="quote">
our hondas dont commonly show the common blown head gasket sings</TD></TR></TABLE>
depends on how bad the gasket is blown
Old Jan 4, 2007 | 05:28 PM
bart2546's Avatar
Default Re: Blown Head Gasket?? (brick top)
Since you don't have any kind of major symptoms typical to that of a blown head gasket, I concur with others by stating a leakdown/compression test will yield the best results for the most truth. If you look in the sticky's there is a lot of great info on how to even do this yourself.
Old Jan 4, 2007 | 05:47 PM
jtchinoy's Avatar
Default Re: Blown Head Gasket?? (bart2546)
if you're not leaking, the only place your coolant can go is your cylinders/ oil pan. Only 2 places to get there through; your IM gasket and your head gasket. 1 or the other is probably busted if you have coolant doing a magical disappearing act.
Old Jan 4, 2007 | 05:53 PM
Si_chRis's Avatar
Default Re: Blown Head Gasket?? (jtchinoy)
Well, if you have the time and funds to fix it, you should do it since your dealer said it was blown. It's prolly not so bad now but it will get worse so it's better to get it done now before it causes any major damage to your enigine.
Old Jan 5, 2007 | 01:52 PM
Thanks, and just to be sure that nothing else is wrong I'm probably just going to buy a new head sometime in the near future, so if any one knows of a good deal on a D16 head please let me know. Thanks again!!!
Old Jan 5, 2007 | 01:57 PM
medside's Avatar
check for bubbles in your oil. pull the dipstick and see if there are bubbles.
if so you most likely have coolant leak in your oil = head gasket blown. not the end of the world because now you can tell people you have a blown civic. haha
Old Jan 5, 2007 | 04:08 PM
Turbo_y8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4theluvofhonda &raquo;</TD></TR><TR><TD CLASS="quote">Thanks, and just to be sure that nothing else is wrong I'm probably just going to buy a new head sometime in the near future, so if any one knows of a good deal on a D16 head please let me know. Thanks again!!!</TD></TR></TABLE>
i have a y8 head, 98k, no valve cover or intake. just the head for 50+shipping
Old Jan 6, 2007 | 07:31 AM
Turbo_y8's Avatar
might sound stupid but is your passenger side floor board wet?
Old Jan 21, 2007 | 04:55 PM
no, but i am definitely interested in the head. is the y8 vtec? because i know the y5 is, but I wasn't sure if the y8 was. ...Still learning.
Old Jan 21, 2007 | 05:00 PM
walsh22's Avatar
y8 is vtec if u have the right ecu..they might be tellin u the gasket is blown to chrage u mad money when u can get a gasket from autozone for 40 and take about an hour to put a new head gasket in.. i did that the dealership wanted 140 for JUST the gasket
IBriaIN
Oct 6, 2008 11:00 AM
CiViC I2aCeI2
Jan 20, 2006 06:49 PM
civic_std
Dec 14, 2005 02:40 PM
gsrvtec2
Oct 16, 2005 12:14 AM
Silvteg95
Aug 8, 2005 04:24 PM
