Fuel Injectors
Hi guys where is a good place to buy injectors? and the setup im running is a comptech supercharger and bolt-ons also a apexi neo A/F controller what would be a decent set of injectors and what size should i run.. thanks for the help
http://www.automotivespeed.com or go to http://www.s2000turbo.com and talk to Kane. The 550cc sounds right for your app, though you could go bigger if you're planning future upgrades.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S@nt0s »</TD></TR><TR><TD CLASS="quote">CAMP1320
all day everyday! i would go 750's at least tho</TD></TR></TABLE>
whos sells them?
whos sells them?
Munkyw3rkz.webs.com
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Widebodys2k »</TD></TR><TR><TD CLASS="quote">I have 1000cc injectors and a 255 lph walbro fuel pump, how much whp could i supply off of this setup, cause i plan to go 30+ psi.</TD></TR></TABLE>
you will def need more then those 1000's
you will def need more then those 1000's</TD></TR></TABLE>
What are you talking about? He has a GT35R why would he need more than 1000cc injectors to max out his turbo? 1000cc's can flow plenty without crazy fuel pressures for 600whp.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kane.s2k »</TD></TR><TR><TD CLASS="quote">What are you talking about? He has a GT35R why would he need more than 1000cc injectors to max out his turbo? 1000cc's can flow plenty without crazy fuel pressures for 600whp.</TD></TR></TABLE>
As far as his setup, (CTSC + bolt ons), I doubt he'll get anywhere near those numbers.
Munkyw3rkz.webs.com
that GT35R on 30PSI plus im sure he will be on C16.. will be well cap. of making over 600...
