Honda S2000 Honda S2000
Fuel Injectors
Old Jan 4, 2007 | 01:04 PM
ITR #1202's Avatar
Default Fuel Injectors
Hi guys where is a good place to buy injectors? and the setup im running is a comptech supercharger and bolt-ons also a apexi neo A/F controller what would be a decent set of injectors and what size should i run.. thanks for the help
Old Jan 4, 2007 | 01:08 PM
Mr. Projekt's Avatar
* B A N N E D *
Default Re: Fuel Injectors (ITR #1202)
http://www.automotivespeed.com or go to http://www.s2000turbo.com and talk to Kane. The 550cc sounds right for your app, though you could go bigger if you're planning future upgrades.
Old Jan 4, 2007 | 02:24 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: Fuel Injectors (Mr. Projekt)
CAMP1320
all day everyday! i would go 750's at least tho
Old Jan 5, 2007 | 02:53 AM
ITR #1202's Avatar
Default Re: Fuel Injectors (S@nt0s)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S@nt0s &raquo;</TD></TR><TR><TD CLASS="quote">CAMP1320
all day everyday! i would go 750's at least tho</TD></TR></TABLE>
whos sells them?
Old Jan 5, 2007 | 05:53 AM
S@nt0s's Avatar
Munkyw3rkz.webs.com
rc's...... camp1320 818.355.5316 Tom
Old Jan 5, 2007 | 07:08 AM
s2kdre's Avatar
if ur gonna use an afc then 550's might be good cause 750's might be hard to get them to idle smooth. u might need a real ems.
Old Jan 6, 2007 | 08:10 AM
ITR #1202's Avatar
Default Re: Fuel Injectors (s2kdre)
thanks for the help everyone.. for you guys with the apex neo where did you mount it at?
Old Jan 7, 2007 | 05:29 AM
Widebodys2k's Avatar
I have 1000cc injectors and a 255 lph walbro fuel pump, how much whp could i supply off of this setup, cause i plan to go 30+ psi.
Old Jan 8, 2007 | 01:31 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: Fuel Injectors (Widebodys2k)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Widebodys2k &raquo;</TD></TR><TR><TD CLASS="quote">I have 1000cc injectors and a 255 lph walbro fuel pump, how much whp could i supply off of this setup, cause i plan to go 30+ psi.</TD></TR></TABLE>
you will def need more then those 1000's
Old Jan 8, 2007 | 09:03 PM
kane.s2k's Avatar
you will def need more then those 1000's</TD></TR></TABLE>
What are you talking about? He has a GT35R why would he need more than 1000cc injectors to max out his turbo? 1000cc's can flow plenty without crazy fuel pressures for 600whp.
Old Jan 8, 2007 | 09:30 PM
* B A N N E D *
Default Re: Fuel Injectors (kane.s2k)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kane.s2k &raquo;</TD></TR><TR><TD CLASS="quote">What are you talking about? He has a GT35R why would he need more than 1000cc injectors to max out his turbo? 1000cc's can flow plenty without crazy fuel pressures for 600whp.</TD></TR></TABLE>
As far as his setup, (CTSC + bolt ons), I doubt he'll get anywhere near those numbers.
Old Jan 9, 2007 | 09:02 AM
S@nt0s's Avatar
Munkyw3rkz.webs.com
that GT35R on 30PSI plus im sure he will be on C16.. will be well cap. of making over 600...
desiromeo812
Mar 31, 2009 10:44 PM
tegman2
Aug 9, 2008 05:18 PM
lskid98
Mar 4, 2008 06:50 PM
Themouse
Jan 19, 2007 07:24 AM
EFb18b
Mar 19, 2004 01:20 PM
