dry ice, how much?
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
i would just get some, then try it out. personally, i never used it. i have been lucky as each time i have done it, dry ice was not needed.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rodney »</TD></TR><TR><TD CLASS="quote">i would just get some, then try it out. personally, i never used it. i have been lucky as each time i have done it, dry ice was not needed.
what did you do?
</TD></TR></TABLE>what did you do?
went in there and peeled it off. most of the time, if you are patient you can peel a majority of it off in one sheet. with a chisel, hammer and a thick putty knife i get the rest of it off. clean up the residue with 3m adhesive remover and call it a day.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rodney »</TD></TR><TR><TD CLASS="quote">went in there and peeled it off. most of the time, if you are patient you can peel a majority of it off in one sheet. with a chisel, hammer and a thick putty knife i get the rest of it off. clean up the residue with 3m adhesive remover and call it a day.
peeled it off with your hands? mines in there good.
</TD></TR></TABLE>peeled it off with your hands? mines in there good.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by latitude »</TD></TR><TR><TD CLASS="quote">peeled it off with your hands? mines in there good.</TD></TR></TABLE>
no, with the aforementioned putty knife and hammer/chisel combo.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by latitude »</TD></TR><TR><TD CLASS="quote">How many lbs does it take around to take the tar/deadening out? I only need to take it out from the back seats to the trunk for now.
Modified by latitude at 2:00 PM 1/4/2007</TD></TR></TABLE>
i used about 20lbs, a chisel, and a hammer. it took me about 30 min. if that.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by junior40er »</TD></TR><TR><TD CLASS="quote">man I used a heater on my first hatch and got all messy and sticky.
the trick is to use the dry ice. break it up, let it sit for about 2-3 minutes, and start chiseling away. it'll come off with little effort.
here is a link that will help:
https://honda-tech.com/zerothread?id=525936
</TD></TR></TABLE>the trick is to use the dry ice. break it up, let it sit for about 2-3 minutes, and start chiseling away. it'll come off with little effort.
slomob18b
Oct 20, 2006 09:07 AM
