Brake Rotors
Old Jan 4, 2007 | 12:35 PM
datssoled's Avatar
Default Brake Rotors
What are some good brake rotors I should pick up for my 1998 civic lx ? What good brands are out there? Does cross drilled rotors make a difference? And I only have front brakes right?
Old Jan 4, 2007 | 12:44 PM
EG2Driver's Avatar
Default Re: Brake Rotors (datssoled)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by datssoled &raquo;</TD></TR><TR><TD CLASS="quote">What are some good brake rotors I should pick up for my 1998 civic lx ? What good brands are out there? Does cross drilled rotors make a difference? And I only have front brakes right?</TD></TR></TABLE>
Get brembo blanks or any blanks for that matter, you're not going to auto-x it or anything. Dont get cross drilled or slotted, doesnt do squat for a street car.
You do have rear brakes
Old Jan 4, 2007 | 12:59 PM
Malakai's Avatar
why brembo blanks?
how can u say drilled/ slotted wont do anything on the street.
I have got my brakes to fade really easily on the street after some spirited driving, sure they are only stock, but an upgrade has to do something better than stock.
and dont get drilled if anything, they are prone to crack.I would get slotted if u are looking.
Old Jan 4, 2007 | 01:18 PM
EG2Driver's Avatar
Default Re: (Malakai)
this thread will become a im right you are wrong about drilled/slotted rotors, but i still think blanks perform better by having more surface area.
Get good pads, like HPS, you will notice a huge difference.
Old Jan 4, 2007 | 01:28 PM
Malakai's Avatar
the main reason i think for upgrades rotors is heat dissipation, which will reduce brake fade. the cooler the brake fluid stays the less likey u are to have fade. pads will work to grab harder, but more friction makes more heat.
Old Jan 4, 2007 | 01:50 PM
EG2Driver's Avatar
then you could use some DOT 4 fluid, which is 100% compatible with DOT 3
Old Jan 4, 2007 | 01:59 PM
Djole_V's Avatar
Default Re: (DeadEnd9009)
are the brembo rotors oem size the slotted ones?
Old Jan 4, 2007 | 02:30 PM
EL Vap133's Avatar
Default Re: (Djole_V)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Djole_V &raquo;</TD></TR><TR><TD CLASS="quote">are the brembo rotors oem size the slotted ones?</TD></TR></TABLE>
Unless you're buying the big brake upgrade, yes they are OEM size.
Old Jan 4, 2007 | 02:31 PM
Malakai's Avatar
also slotted help keep brake dust down.
Old Jan 4, 2007 | 03:31 PM
datssoled's Avatar
so i should pick up blanks or slotted at the most ? brembos or any aftermarkets should work right? same goes with brake pads right?
Old Jan 4, 2007 | 03:38 PM
JDM-97CX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Malakai &raquo;</TD></TR><TR><TD CLASS="quote">also slotted help keep brake dust down.</TD></TR></TABLE>
No it doesn't.
Will you people stop posting like this. You just make some outrageous statement and then give no information to back it up. Most of it is something you heard from some moron at the "street races".
No one needs your misguided input.
Old Jan 4, 2007 | 03:39 PM
doood's Avatar
been there done that
Default Re: (datssoled)
just go to autozone and get some oem replacements. cheap as pie and do the same thing. even slotted rotors can crack.
Modified by doood at 12:55 AM 1/5/2007
Old Jan 4, 2007 | 03:43 PM
B16b-EJ8's Avatar
Ok since you asked a question that has been covered MANY times i figured i would just do the search for you (since it only took me 10 seconds to find) and provide you with a link to ALL the info you will need for making your decision...
https://honda-tech.com/zerothread?id=1437507
Old Jan 5, 2007 | 02:34 PM
Malakai's Avatar
Default Re: (JDM-97CX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM-97CX &raquo;</TD></TR><TR><TD CLASS="quote">
No it doesn't.
No one needs your misguided input.</TD></TR></TABLE>
how can you say it doesnt? where is your info to back this?
stick a thumb up ur *** and walk!
Old Jan 5, 2007 | 02:45 PM
doood's Avatar
Default Re: Brake Rotors (B16b-EJ8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Malakai &raquo;</TD></TR><TR><TD CLASS="quote">how can you say it doesnt? where is your info to back this?
stick a thumb up ur *** and walk!</TD></TR></TABLE>
guess you didnt see this post?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16b-EJ8 &raquo;</TD></TR><TR><TD CLASS="quote">
https://honda-tech.com/zerothread?id=1437507</TD></TR></TABLE>
now take your own advice
Old Jan 5, 2007 | 06:14 PM
robnbig's Avatar
dont get drilled they do crack when they heat up.. i suggest getting slotted brembos all slotted rotors do btw is catch brake dust that would normally stay on your rotor if you had blanks
i suggest getting slotted rotors with steal brake lines and some good pads
Old Jan 6, 2007 | 03:43 PM
datssoled's Avatar
Default Re: (robnbig)
wow that link is good. i probably should search up the archives next time
Old Jan 6, 2007 | 04:50 PM
bmoua's Avatar
well i had some pbr ceramic brake pads streets with brembo slotted/drilled rotors and it worked okay. After 6 months though the rotors were warped dont know how? then 3 months after my pbr brake pads started to chip and make loud screaking noises. Setup i have now which will go in tomorrow is oem resurfaced rotors with hawk hps pads...In your case i'd go with my setup that i chose.
standbackimapro
Sep 21, 2007 11:27 AM
sin2o3
Sep 5, 2007 12:20 PM
jorge99hx
25
Dec 10, 2005 12:52 PM
ITR #0202
Nov 17, 2002 08:50 AM
EF_LSVtec
May 30, 2002 02:35 AM
