95 ej1 over heating
i have a 95 civic coupe ex. i jumped the fan and it worked but it wont turn on while the car is running. i checked the fuses, and the relay. the wiring to the fan looks good too. the engine over heats at idle but cools down while i am driving. which is just air passing through the radiator. what could it be? radiator is full of coolant. the fan just wont turn on. the fan on the condenser does.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zbass06 »</TD></TR><TR><TD CLASS="quote">thats what i was thinking. i'm sorry i havn't been able to go pick up a helms manual yet. where is it located?</TD></TR></TABLE>
I was just looking for that and I can't find it on older civics. Let me see if I can find anything else for it.
i went out and got a new fan switch and put it on and am still not getting any fan movement. so that means ive gone over the fuse, relay, fan switch, coolant. and the wiring appears good, but i would think that is the only thing left. is there anything else to check
ok this is gonna sound bootleg but just do it .. it worked for me .... take a garden hose cut off the end where the water comes out... now take off your top radiator hose at the radiator not the block.. now jam the cut hose end into the radiator and let the hose rip this will force feed water through the motor and push it back out the hose that you disconnected and you will most likely see milky air filled water running out i did that 5 months ago and my car hasnt overheated since plus im a hvac service tech so i figured id get the air out of my engine the same way i do in a hydronic heating system lol
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by void_accord »</TD></TR><TR><TD CLASS="quote">might be the thermostat sensor</TD></TR></TABLE>
check it...
check it...
ok the fan switch was replaced, relays and fuses are good, wiring appears good, the fan doesnt come on at all and the car overheats. it has 230k miles. would the thermostat sensor cause for the fan not to come on? also when i replaced the fan switch the clip for the harness didnt go back on right. it didnt clip but was on all the way. if i replace the thermostat sensor and that doesnt work either then what? its my friend's(zbass06) civic i have been helping him out with it
we bled the system with the bleeder valve. the fan didn't come on. how do i check the thermostat sensor. how would that effect it? the thermostat is opening, both hoses are hot
ok so i jumped the fan switch and the fan came on. is it a bad new switch or air int eh system? i bled with the bleeding vlave int eh front of then engine no air was coming out
there is a way to hook up the fan so when your car is on its stay on and when you cut the car off it goes off i'll try to see how i did it but thats just a short cut you might wanna do it the right way so go with what they said then you can do what i did if you want too
FoRizzyy
Jun 6, 2012 01:09 AM
oskar_0709
Dec 2, 2010 10:47 AM
Brian30324
Jun 29, 2007 08:05 PM
rasta420
11
Nov 20, 2002 08:05 AM
