Cabin Fan switch Heater/AC
Old Jan 4, 2007 | 09:54 AM
EDDY MERCX's Avatar
Default Cabin Fan switch Heater/AC
2000 EX Accord 4cyl
Cabin Fan switch Heater/AC, does not function on lower two speeds (1) & (2) yet (3) & (4) work.
Is it the switch or the Fan motor?
Where Can I locate switch on-line, Looking and have not found it yet. Maybe I am not looking with correct name.
Old Jan 4, 2007 | 10:33 AM
JimBlake's Avatar
Default Re: Cabin Fan switch Heater/AC (EDDY MERCX)
Look instead for the fan control resistor, #7 underneath the blower housing. Not working on lower speeds while it works on higher speeds is pretty classic for that. Dirty/loose wiring connections?
ps... like the name. Do much riding??
Old Jan 20, 2007 | 06:12 AM
66elwood99's Avatar
Default Re: Cabin Fan switch Heater/AC (JimBlake)
I'm having the same issue with my son's 96 ex. Is this accessible without taking apart the dash? Do you have the steps to access it? Would cleaning up the connections fix it or should I get a new #7?
Thanks
Modified by 66elwood99 at 6:53 PM 1/20/2007
Old Jan 21, 2007 | 06:49 PM
JimBlake's Avatar
Default Re: Cabin Fan switch Heater/AC (66elwood99)
That picture is for 2000, 1996 would be different. Go to hondaautomotiveparts.com & put in your year & model, see what it looks like. Picture is probably called heater fan or something like that.
I don't have a '96 but I suppose you have to remove some trim panel(s) under the glovebox. Maybe remove the glovebox??
It's dumb luck whether cleaning the connections would work, but I'd try it first. If the problem is a failed resistor within that resistor pack, then cleaning the contacts won't help.
Old Jan 23, 2007 | 04:37 AM
66elwood99's Avatar
What a great site, thanks for the info!
Crazy_SI_T
Audio / Security / Video
Apr 4, 2011 06:12 AM
strngblkman
Oct 18, 2010 07:29 PM
jooky5
Jan 30, 2009 10:23 AM
AaronJ
Aug 1, 2007 09:50 AM
ramoneguru
Feb 14, 2007 06:28 PM
