Want to daily run 6psi. What is needed?
Old Jan 4, 2007 | 07:25 AM
Diyracing2's Avatar
Default Want to daily run 6psi. What is needed?
I want a turbo setup that i cna run 6psi daily. Daily driven. Not building teh bottom end, leaving everything stock.
Anyone have a good write up???
1994 Civic DX
B18c1 JDM
Any suggestions would be great.
Old Jan 4, 2007 | 08:02 AM
turboparts's Avatar
Default Re: Want to daily run 6psi. What is needed? (Diyracing2)
write up i cant do cause i am too lazy but run a small turbo t3/t4 and you can actually run up to 12psi on stock motor on the safe side but i know people who ran 22psi on stock motor it didnt last them that long but long enough to say it could be done.
Old Jan 4, 2007 | 08:19 AM
Diyracing2's Avatar
Default Re: Want to daily run 6psi. What is needed? (turboparts)
Im so new to this turbo stuff. BUilt tons of motors, never tried turbo.
t3/t4. what brand???
Injectors? Fuel management.? I want it running like stock.
Old Jan 4, 2007 | 08:28 AM
b18sihatch's Avatar
getting it to run like stock can cost money, reason being is you need a good kit to start out with, something that isnt garbage and something that wont break fast.
then you need, fuel management, engine management (ecu), great tune
but that is if you get legit parts and do it right.
not alot of people do that. but tuning is key to getting your car to run like stock, and make respectable power
turboparts's Avatar
Garrett t3/t4
550 injectors
chipped ecu or s-afc
its not much to it someone can probably help more than i can cause im just to freaking lazy
Old Jan 4, 2007 | 08:32 AM
b18sihatch's Avatar
actually, if you are wanting to have the car run like stock.
TUNING & ECU will be your key parts in getting the car to run right.
safc hack will be the least possible option to getting your car to run like stock as safc doesnt do barely any of which a chipped ecu can do.
tuning will get your timing,ignition,fuel curve ect set right.
but again, you can get into a good ammount of money just getting your car to run right, most people put alot of concern with the turbo kit itsself to get a motor to run good, however its tuning and your managements that get your car to run correctly.
turbo kits just get it to perform to its maximum potential
Old Jan 4, 2007 | 08:43 AM
PrecisionH23a's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Diyracing2 &raquo;</TD></TR><TR><TD CLASS="quote">Im so new to this turbo stuff. BUilt tons of motors, never tried turbo.
Injectors? Fuel management.? I want it running like stock.</TD></TR></TABLE>
With the right tuning, you can have your set-up running the same as stock and even get better fuel economy than stock. It's all in the tune... I prefer to use hondata. You can get more info at http://www.hondata.com
Old Jan 4, 2007 | 10:06 AM
morgan@synapse motorsport's Avatar
Default Re: Want to daily run 6psi. What is needed? (PrecisionH23a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrecisionH23a &raquo;</TD></TR><TR><TD CLASS="quote">
With the right tuning, you can have your set-up running the same as stock and even get better fuel economy than stock. It's all in the tune... I prefer to use hondata. You can get more info at http://www.hondata.com</TD></TR></TABLE>
definately. im getting better gas milage than a stock gsr, and it runs great. with a proper tune every turbocharged car should run great.
Old Jan 4, 2007 | 11:04 AM
Diyracing2's Avatar
Default Re: Want to daily run 6psi. What is needed? (hybrdthry911)
your telling me your getting 600hp and getting better gas mileage then a stock gsr. DOUBT IT. ahaha.
whats a good ecu to run. Decent priced that will allow me to tune my af and what i need???
Old Jan 4, 2007 | 11:14 AM
93CX's Avatar
when you have a turbo that you have to rev to 6k to get to spool, its not hard at all
Old Jan 4, 2007 | 12:28 PM
katoeh2o's Avatar
I got better gas mileage after tunnig my car on crome while turbo. If you are boosting alot and redlineing it you will eat alot of gas but for normal crusing you can tune your part throtle map for good gas milage.
When I ran my wide band o2 with my p30 ecu and not turbo I was suprised to see my air/fuel ratio was between 13.5-12.5. Combine that with my b16 tranny =about 16-18 mpg. After tunnig and turbo regular boosting =22-25mpg.
By the way I have been running t3 .48/.60 at 7-9lb of boost on my stock b16a2 for almost 2 years now. In about a week or two I will have a larger t3/04e 57 trim turbo can wiat.
Old Jan 4, 2007 | 04:54 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Diyracing2 &raquo;</TD></TR><TR><TD CLASS="quote">your telling me your getting 600hp and getting better gas mileage then a stock gsr. DOUBT IT. ahaha.
whats a good ecu to run. Decent priced that will allow me to tune my af and what i need???</TD></TR></TABLE>
im a pretty conservative driver when i want to be. my highway mpg is mid 30's. drove to boston and back on a tank of gas about 390 miles give or take. i took it pretty easy on this trip since it was the first day i had it on the road. sure if i was running full boost, and got on it all the time it would be in the single digits. but i know the setup is capable of getting better than stock gas mileage when im not boosting it all day.
crome, hondata, or neptune are all fair priced or free and work great.
Old Jan 4, 2007 | 04:57 PM
Synapse Motorsport's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybrdthry911 &raquo;</TD></TR><TR><TD CLASS="quote">
crome, hondata, or neptune are all fair priced or free and work great.</TD></TR></TABLE>
1000 cc's and 30 mpg Its all in the tuning.
Lawbags
Oct 6, 2017 05:15 AM
machine4321
May 7, 2007 10:58 AM
AZ90DATEG
Feb 27, 2007 04:18 AM
memorybox
Aug 28, 2006 11:12 AM
civiceg500
Jul 21, 2004 05:10 PM
