Compression #'s for B18B1
Hey whats up guys. Wondering if anybody could tell me the compression #'s for a stock B18B1. I've searched but cant find anything on it. Thanks.
I know they should be consistent I just wasnt sure where they should be at all. I've always had cars with VTEC and those were always higher. Thanks for the input though.
all compression test will result differently
just make sure the car is very warm before you do the test, and pull your ecu fuse out before you perform the test to avoid spark and letting fuel enter the motor
as long as each cylinder is within 10% of eachother then you have no major problems
builtprelude
Jan 22, 2004 10:49 PM
